LG led with black screen
sprinklerman
Feb 26, 2018, 8:52 PM
Post #1 of 18 (2555 views)
LG led with black screen Can't Post
My 55" LG led tv, model #55LW5600, screen faded to black right in front of my eyes. I purchased a T CON board thinking that was a cheap easy fix. It didn't work. Please help me before I take it out back and fill it with 9mm holes. Thanks in advance.
Feb 26, 2018, 11:07 PM
Post #2 of 18 (2544 views)
Re: [sprinklerman] LG led with black screen [In reply to] Can't Post
Careful, they've been known to return fire. Smile
Ballboy1066
Feb 27, 2018, 2:13 PM
Post #3 of 18 (2532 views)
Hi,
Firstly, I'm not an expert in TV repairs but, I have a lot of experience in other spheres to do with communications. There is wealth of information at your finger-tips nowadays on the I-Net.
I personally would not buy anything at the stage you're at until you've established what was causing the issue i.e. black screen. It might well have been the T-Con board but, you need to establish that with the 'Flashlight test' -see 'ShopJimmy' YouTube post-.
Now you're in a situation whereby the old T-Con, and the new for that matter, needs to be tested in the TV to see they produce an image on your black screen. If the old one is okay fine.. test the new one too.. if that's fine you could always sell it and recoup some cash to finance the real issue?
Have a look at the 'Youtube' posts -below- (there's lots more but, for my issues -similar to yours- I found them amongst the best; the technician's in them have different methods but are sound -IMHO-). I would do this research even before touching the TV.. you may need to buy/borrow/beg some test-meters.. In any event (and above all).. you need to adhere to health and safety. I apologise if I appear to be preaching but I hold your best interests at heart.
https://www.youtube.com/watch?v=2pyuXwNkBMA
https://www.youtube.com/watch?v=Bf5T2wwtydY&t=217s
I think it's worth persevering with.. you may end up with your TV back and not in the dumpster...
Hope this helps.. good luck.
sprinklerman
Feb 27, 2018, 2:40 PM
Post #4 of 18 (2526 views)
Re: [Ballboy1066] LG led with black screen [In reply to] Can't Post
Thanks for the advice.
I have watched several videos and tried different test.
I will surely try these when i get home.
Notice the web address below.
Check out the test on page 58-59. Apparently the SMPS and Inverter are OK because the back light came on during test. I should mention that the back light will not come on by itself. Also the flash light test didn't work with either T-CON board.
Thanks again for the help! I refuse to give up on this thing.
http://pages.sssnet.com/test/LG_55LW5600_Training.pdf
Feb 27, 2018, 8:46 PM
Post #5 of 18 (2523 views)
With everything back to how it was when you first removed set back, What are PWR-ON & DRV-ON pins of P201 doing when you try to power up TV? Is relay engaging?
sprinklerman
Feb 28, 2018, 1:21 AM
Post #6 of 18 (2513 views)
Re: [jts1957] LG led with black screen [In reply to] Can't Post
Yes I can hear the click. When AC power is removed I can also hear the click after the capiciters power down.
Feb 28, 2018, 1:54 AM
Post #7 of 18 (2510 views)
sprinklerman
Feb 28, 2018, 2:08 AM
Post #8 of 18 (2506 views)
You’ll have to excuse my ignorance. When I pull the P201 plug from the SMPS board to test those pins I get nothing. Nothing from any of the pins on that plug. Same for if I pull the P502 plug from the main board. Relay does however click on when I plug back in.
Feb 28, 2018, 2:21 AM
Post #9 of 18 (2506 views)
With everything back to how it was when you first removed TV set back, What are PWR-ON & DRV-ON pins of P201 doing when you try to power up TV? Is relay engaging?
Who asked you to unplug some thing?
I asked what those two pins of P201 and relay were doing.
sprinklerman
Feb 28, 2018, 2:29 AM
Post #10 of 18 (2501 views)
I didn’t know how to get to the 24 pins with out doing so. There are only 12 legs I can test on P201. The PWR-ON is getting 3.2 volts while the 4th leg from the top (17 or 18) is getting 11.9.
Sorry I’m a pipe fitter by trade so excuse my lack of terminologies.
Feb 28, 2018, 2:47 AM
Post #11 of 18 (2500 views)
Back probe the connector from the wire side. Pg 58 for P201 pinout. Board itself, Top & Bottom, are also labeled.
(This post was edited by jts1957 on Feb 28, 2018, 3:00 AM)
sprinklerman
Feb 28, 2018, 3:23 AM
Post #12 of 18 (2493 views)
PWR-ON is at 3.2 and DRV-ON is 0.
Feb 28, 2018, 11:54 PM
Post #13 of 18 (2484 views)
Jumpering DRV_ON to 3.2V does NOT cause BL to turn on when set is turned on? & BL does NOT come on when either P202 or P203 is disconnected? IF NO to these, plug all back in & remove jumpers then set a hair dryer on highest setting and heat components on the Main board (microprocessor & big heat sink especially) for about 5 minutes then try to turn TV on. IF BL come on when hot, Bad Main board.
sprinklerman
Mar 1, 2018, 1:38 AM
Post #14 of 18 (2479 views)
Jumpering DRV ON to 3.2v DOES turn on the BL. BL does NOT come on when either P202 or P203 is disconnected.
Should i still try th hair dryer?
The colors got distorted and then faded to black in a matter of fifteen minutes. Does this sound like a main board going bad?
Thanks
Mar 1, 2018, 2:28 AM
Post #15 of 18 (2477 views)
Try it. I've seen others with that solution.
sprinklerman
Mar 2, 2018, 2:46 AM
Post #16 of 18 (2476 views)
It didn’t work
sprinklerman
Mar 3, 2018, 2:10 PM
Post #17 of 18 (2466 views)
Any other ideas? I’m starting to think it has to be the main board. The new T CON board didn’t work. When i did the jumper test the LEDS came on. What else could it be?
Mar 3, 2018, 7:03 PM
Post #18 of 18 (2461 views)
Main boards are cheaper than panels.
