Jul 2, 2008, 9:29 AM
Post #2 of 3
(74 views)
Re: [PurpleRoadie] Logik LCX27WN2 no picture
Most of these you have to fix cold as there is no way to test live. The inverter board is just a chopper supply feeding several little transformers which are in effect starters for the backlamps. The usual is chech the driver transistors for shorts and check the transformer resistance. You have several so check each reads the same. failing that and I just did 2 BENQ with a backlamp out at 4 years so thats your likely.
