Looks like good info here
sportstv
Aug 30, 2012, 11:46 PM
Post #1 of 1 (21996 views)
Looks like good info here Can't Post
surfing other sites I found a site. you have to log in to post, but you can read everthing for free. we need a lot of help in this quest to save repair money.
http://sweepsforum.createaforum.com/index.php
sony blink codes
Unit is dead, No blinks - Problem in the standby power section. Might check fuse, R607, Q601, IC601, R612 and VDR601 (should show open).
Continuous blink once a second, no pausing - No reply from the jungle IC301 (data bus is busy, shorted to ground, or held high), IK video path is defective.
One blink - not used for the self-diagnosis
Two blinks - B+ over current protection (OCP), unit goes to the standby mode then displays the 2 blink fault. Could be a short in the power supply of any of the circuits.
Three blinks - B+ over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is also a problem in the power supply circuit, check T603 and R672.
Four blinks - No vertical Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted. Check IC1509, Q1505
Five blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
Six blinks - No Horizontal (H STOP), no raster, goes to the blinking self-diagnosis function immediately. Check C515 & 516 and the jungle IC, IC206.
Seven blinks - High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits.
Eight blinks - Problem with the audio (AUDIO), unit goes to standby and blinks the self-diagnosis code. Check IC406 audio amp, PS401, and 402. On some projection models of Sony TV sets, this code means that T8005 (flyback transformer), or the associative components in the high voltage circuits are defective on the D board.
Nine blinks - Replace D 6116 and D 6301 on the "G" board, do not resolder as this will fix the problem temporary. Or Panel Module Error or Thermal Error. If it is intermittent 9 blinks, meaning sometimes the TV comes on and other times you get flashing, then change the switching regulator on the "G" board or check connections. Make sure the regulator is -12 or -13 (negitive).
Ten blinks - Check Q8014 and Q8013 for shorts, leakage, or bad solder connections on the " D" board. If the transistors are bad, check R8051 and IC8005, also on the "D" board.
Intermittent problems? This is a great feature. You can also bring up these fault codes on-screen to see a list of the problem numbers with the abbreviation of the problem and the number of times this problem has occurred. This is slightly different than entering the service mode. To see the diagnostic screen, press the following buttons: Display, Channel, 5, volume Minus, ( not plus ) then Power. This brings up a screen with a list of the problems and number of times they have occurred. Each of the problems named, are abbreviated as, "OCP", "OVP", "V STOP", ETC. We have repeated them in parentheses in the text for the "Blinks" described above so you can correlate between the diagnostic screen and the blink codes.
IMPORTANT: After you repair the unit, you MUST clear the values on this diagnostic screen. These codes do not reset themselves after the fault is corrected, so if you don't clear them, you'll be seeing "old" fault codes the next time you enter this screen. Clearing is done by going into the service mode (display, channel, 5, volume plus, then power ). Press 8 and Enter, which returns everything to the factory preset condition.
panasonic blink codes for lcd
Here is Some Panasonic Blink codes for quick repair Of LCD TV.
TC14LA2 Dead set. No response to any button. The external power supply is delivering the correct +15Vdc to the TV rear.
Check or replace the N channel MOSFET Q8, located on the Driver board.
TC19LX50 No picture. Power LED blinks 9 times.
No communication between GC4 IC4016 and the Main micro IC1103. Replace A board with part number TXNA10LFM.
TC22LR30 LED blinks once every 5 seconds. Unit appears to be dead. No picture, or Audio is present.
Check for the backlight voltage on connector P2, Pins 9-15 (15V), and Pins 1-7 (gnd).
TC22LT1 Excessive brightness.
Check pins 3, 4, and 5 of connector N009B for 15V which is the source voltage for the LCD Panel inverter power supply. If it is ok, replace the LCD Panel.
TC23LE50 No picture. Power LED blinks 2 times
. Replace the power unit if the 24V is missing. If 24V is present, change the LCD panel
Model Symptom Possible Remedy
TCL37D2 The unit shuts down and the power LED blinks 10 times. 1. Disconnect the connectors CN01 and CN02. If the unit powers up and stays on with no picture , Replace the LCD panel.
2. Reseat the connectors A10 and V10. Confirm the operation of the unit.
3. Before the unit shuts down, quickly check the DTV12V coming from the power supply. Confirm its presence on the A board. If missing, use an ohmeter to determine the location of the short (P or A board). If there is not a short, replace the P board.
TCL37D2 At power up, the screen flashes and the unit shuts down. the power LED blinkS 9 times. Check connector A21, it may not be seated properly.
TCL37D2 When troubleshooting for a shutdown, panel’s disconnection may become necessary. Click here to see a hint on panel’s disconnection
TCL37G1 The TV shuts down and the power LED blinks 1 time. To determine the source of the defect, click here for a troubleshooting hint.
TCL37G1 Emergency Alert System (EAS) message continues to display on TV after the warning has terminated. The problem is corrected with PEAKS software version 1.27 for X1 models and version 1.28 for S1, G1 and U12 models.
TCL37G1 SD card motion video does not play. The operating manual incorrectly states “lets you easily view still and motion image….by inserting an SD card…
Actually, only still pictures from an SD card can be displayed on the TV.
TCL37G1 No OSD, No Video, the unit only displays the internally generated diagnostic patterns. Reseat the LVDS connector at both ends (the A board and the panel).
TCL37G1 After replacing the P or A board, the unit is dead. There is no relay click. Check pin 23 of connector P2/A03. It is probably bent, causing the a board not to receive the STB5V from the power supply.
TCL37G1 “OOO” appears in the middle of the screen and “Temp” appears at the upper right corner. Reset the TV by holding the front panel Volume Down button and the remote control OK button for 4 seconds.
TCL37G1 After replacing the A board, the unit is stuck in the Service Mode. Try each of the two steps one at a time until the unit comes out of the service mode and display “First Time Setup”
1. Vol – on TV and Menu on the remote simultaneously for 3 seconds or more.
2. Vol – on TV and OK on the remotesimultaneously for 3 seconds or more.
TCL37S1 The unit shuts down and the power LED blinks 14 times. Replace the A board.
TCL37S1 After replacing the P or A board, the unit is dead. There is no relay click. Check pin 23 of connector P2/A03. It is probably bent, causing the a board not to receive the STB5V from the power supply.
TCL37S1 “OOO” appears in the middle of the screen and “Temp” appears at the upper right corner. Reset the TV by holding the front panel Volume Down button and the remote control OK button for 4 seconds.
TCL37S1 Power relay keeps cycling on/off. Check for a short (maybe caused by a coin) in the SD card input slot.
TCL37S1 The TV shuts down and the power LED blinks 1 time. To determine the source of the defect, click here for a troubleshooting hint.
TCL37S1 No OSD, No Video, the unit only displays the internally generated diagnostic patterns. Reseat the LVDS connector at both ends (the A board and the panel).
TCL37S1 No or intermittant backlight. Unit may shutdown with a 1 blink error code. Follow these steps to determine if the panel backlights or the power supply (P) board is bad:
1. Unplug both backlights from the P board.
2. Plug the TV in, wait for the relay to finish clicking on and off.
3. While watching the S101 neon lamp on the P board, press the power button .
With the backlights disconnected, this lamp should come on within 10 seconds, then go off.
Conclusion:
If the S101 lamp never comes on, the P board is bad. If the S101 lamp does turn on, the backlights are bad.
TCL37S1 SD card motion video does not play. The operating manual incorrectly states “lets you easily view still and motion image….by inserting an SD card…
TCL37S1 After replacing the A board, the unit is stuck in the Service Mode. Try each of the two steps one at a time until the unit comes out of the service mode and display “First Time Setup”
TCL37S1 Emergency Alert System (EAS) message continues to display on TV after the warning has terminated. The problem is corrected with PEAKS software version 1.27 for X1 models and version 1.28 for S1, G1 and U12 models.
PT40LC12 Lamp is making Noise Check the Lamp Connector
PT40LC12 Dark Screen Check the Center filament of the bulb it should be clear not gray or black
PT40LC12 Image is reversed on screen Change the LR setting in Factory mode from ON to OFF. 1) Press and Hold the Volume Down Button on the Center Panel and press the Recall Button on the remote until Work Mode is displayed on the bottom of the screen. 2) Press and Hold the Volume Down Button on the Center Panel and press the Swap Button on the remote until Factory Adjust is displayed on the screen. 3) Use the Channel down button to select DIGITAL and press the Action button. 4) Select LR from the menu and change the setting from ON to OFF
PT40LC12 Red, Green or Blue Horizontal line Check the LCD/Prism Unit
PT40LC12 Brightly Lit Pixel Check the LCD/Prism Unit
PT40LC12 When using the PC input, the OSD information is faded and the entire screen flickers Check the Phase adjustment
PT40LC12 Fixed Bluish and/or Greenish and/or Reddish blob(s) visible on screen when set is on. Dust particles must have been sucked into the Projector Unit and got attached to the LCD Panels. Click here for remedy
PT40LC12 TV does not come on. Power LED blinks 2 times. Lamp cover switch is open. p/n = LSEP3052A
PT40LC12 Shuts down. Mild ballast transformer burn odor from the TV rear. Ballast damaged. Lamp elements may have shorted, damaging the ballast. Check the lamp for loose elements inside before powering up the set with a new ballast.
PT40LC12 Quick lamp time reset procedure. 1. Turn the TV on.
2. Hold the VOLUME DOWN button on the front panel
3. Hold the remote control’s PIP / PLAY button in at the same time. After 10 seconds, the OSD message will display “Lamp time was Reset to 0″. Only the EUR7603Z80 OEM remote has the Play / PIP button that works.
PT40LC12 Power LED blinks continuously. If the thermal fuse above the lamp housing is bad, replace it and check for reduced fan-speed that could be caused by dirt, lower than 7Vdc source, or duct blockage. If the fuse is OK, replace the ballast assembly.
PT40LC12 Unit shuts down after operating between 2 to 5 minutes. The TEMP LED blinks 3X. Check the Lamp Thermistor R2901 (280k ohms at room temperature) located above the Lamp housing. Also check the Front Thermistor R2911(60k ohms at room temperature) located behind the filter which is behind the right speaker grill when facing the TV. If both thermistors are OK, resolder the main board by connector P6205 and microprocessor IC6001/pins 87-88.
PT40LC12 Picture “blinks”! TV works for a period of 5 mins to an hour then goes dark but the video and audio return within 20 seconds only to go out again within an hour. The Mercury vapor lamp is the primary suspect.
PT40LC12 Jail Bars in Picture 1. Reseat connectors P2001, P2002 and P2003.
2. Press the volume button. If the bars go through the OSD (OSD is behind the bars), replace the light engine. If the OSD is clean (no bars in the OSD), the problem is in the Main board or prior video processing, not the light engine.
PT40LC12 Picture is Keystone shaped Check the Projection Assembly.
1. Reposition the lens from the front after loosening 4 side screws. See the service manual for pictures if needed.
2. Check the metal supporting the screen just above the lens assembly to see if it is bent.
3. Replace the optical assembly as the last resort.
PT40LC12 Red, Green, or Blue vertical or horizontal stationary lines in the picture, using any input. Replace the light engine
PT40LC12 Screen flickers and the OSD is faded when using the RGB PC input. Adjust the Phase:
1. Press the ASPECT remote button
2. Highlight SCREEN
3. Press ACTION for the menu screen
4. Select ADJUST
5. Adjust for minimum flicker
PT40LC12 Split picture (Picture with picture) image does not fill the screen at the sides (left & right) The thin black sides are normal in this mode.
PT40LC12 Picture is Distorted Check the Tilt and Focus Adjustment
PT40LC12 Ghosting in all modes even OSD information Check the Projection Assembly
PT40LC12 Greenish picture on all inputs and the menu Replacement of LCD Light Engine resolved the problem
PT40LC12 No audio when using video 3 or RGB audio input, and audio level is low when using component video inputs.
Audio output by the “Line audio” output jack on the rear panel is distorted. Main board SW -5V regulator SMD transistors Q1030 and Q1031 are suspect. Replace the transistors located under the Main board.
panasonic blink codes for plasma
Panasonic
Consumer Plasmas
2011 Models :
ST30 / GT30 / VT30
Code:
BLINKS PROBLEM CHECK POINT
1 blink Panel Info SOS * No Info Given *
LP1 Start SOS
3 blinks P+ 3.3v SOS A-Board
4 blinks Power SOS P Main-Board / P Sub-Board
P-Board / P2-Board
5 blinks P+ 5v SOS A-Board
6 blinks Driver SOS 1 SC-Board / A-SC FPC
SC Energy Recovery Circuit
A-SC FPC DET
7 blinks Driver SOS 2 SU-Board / SD-Board
SU/SD Connector DET
SU/SD Scan and Logic IC
8 blinks Driver SOS 3 SS-Board / SS2-Board / SS FPC / SS2 FPC
SS FPC Detect
SS Energy Recovery Circuit
9 blinks Discharge Control SOS A-Board
10 blinks Sub 5V SOS / Sub 3.3v SOS A-Board / SC-Board / SS-Board / P Main-Board / P Sub-Board
Tuner Power SOS
11 blinks Fan SOS A-Board / Fan
12 blinks Sound SOS A-Board / Speaker / Woofer
13 blinks Emergency SOS A-Board
14 blinks IR LED SOS A-Board
BOARDS DESCRIPTION:
P MAIN Board = Power Supply (VT30 Models) - Non-serviceable. Must be replaced for service.
P SUB Board = Power Supply (VT30 Models) - Non-serviceable. Must be replaced for service.
P Board = Power Supply (All Other Models)
P2 Board = Power Supply (All Other Models)
A Board = Main AV Input / Processing
K Board = Remote Receiver / Power LED / C.A.T.S. Sensor
S Board = Power Switch
V Board = 3D Eyewear Transmitter
C1 Board = Data Driver (Lower Right)
C2 Board = Data Driver (Lower Center)
C3 Board = Data Driver (Lower Left)
SC Board = Scan Drive
SS Board = Sustain Drive
SS2 Board = Sustain Out (Lower)
SU Board = Scan Out (Upper) - Non serviceable. Must be replaced for service.
SD Board = Scan Out (Lower) - Non serviceable. Must be replaced for service.
2010 Models :
X24 / C2 / U2 / S2 / G20 / G25 / VT20 / VT25
Code:
2 blinks 15v SOS D-Board / P-Board
3 blinks 3.3v SOS D-Board
4 blinks Power SOS P-Board
5 blinks 5v SOS D-Board
6 blinks Driver SOS 1 SC-Board / D-SC FPC
D-SC FPC DET
SU/SD Connector DET
SS FPC Detect
9 blinks Discharge Control SOS D-Board
10 blinks Sub 5V SOS / Sub 3.3v SOS A-Board / SC-Board / SS-Board / P-Board
Sub 9V SOS / Tuner Power SOS
MIHO 3.3 SOS / LED 8v SOS
2009 Models :
PX14 / PS14 / C1 / U1 / X1 / S1 / G10 / G15 / V10
Code:
1 blink STB 5v SENSE Time Out A-Board
2 blinks 15v SOS A-Board
3 blinks 3.3v SOS A-Board
5 blinks 5v SOS A-Board
6 blinks Driver SOS 1 SU-Board / SD-Board / SC-Board / SS-Board
(SC/SS Energy Recovery Circuit)
7 blinks Driver SOS 2 SU-Board / SD-Board / SC-Board
(SC Floating Voltage Area)
(SS FPC/ DET)
9 blinks Communication Error between A-Board
Panel-MPU and SYS-MPU
10 blinks Sub 5V SOS / Main 3.3v SOS A-Board
DTV 9V SOS / Tuner Power SOS
13 blinks Communication Error A-Board
with IC8001
2008 Models :
PX80U / PZ80U / PZ85U / PZ800U / PZ850U
Code:
1 blink STB 5v SENSE time out A-Board
(SC Energy Recovery Circuit)
(SS Energy Recovery Circuit)
9 blinks Communication Error between A-Board / D-Board
10 blinks Sub 5v SOS / Main 3.3v SOS A-Board
DTV 9v SOS / Tuner Power SOS
11 blinks Fan SOS PB-Board
with IC8001 (Pesks PRO)
2007 Models :
PE77U / PX75U / PX77U / PZ77U / PZ700U / PZ750U
Code:
1 blink STB 5v SENSE Time Out DG-Board
9 blinks Panel Config SOS
10 blinks Sub 5v SOS / Main 3.3v SOS DG-Board
12 blinks Sound SOS H-Board
13 blinks Communication Error with DG-Board
IC8001 (Pesks Lite 2)
2006 Models :
PD60U / PX6U / PX60U / PX600U
Code:
9 blinks Panel Status
10 blinks PA SOS / Tuner SOS PA-Board / H-Board
11 blinks Fan SOS Fan
12 blinks Sound SOS PA-Board
