Mar 26, 2005, 9:13 PM
(988 views)
Re: [shubachs] Loose coax connector causing screen blackout
A bad tuner will normally result in the lose of both video and sound. Your symptom sounds more like a bad solder joint or cracked PC board, in the video section, which makes contact when you flex the board when jiggling the connector. Using a non-conductive probe, probe around the board to see if you can isolate the offending area and then use a magnifying glass to see if you can spot the problem. You might also want to check out www.FreeFlatScreens.com/?r=10948674 for an opportunity to earn a free replacement for this set with a little effort on your part.
