seekeril
Nov 3, 2004, 10:44 PM
Post #5 of 6
(2185 views)
Re: [mikemaiertv] Mitsubishi 50" won't power up
After repeated attempts to power it up (with no luck). The same code is still there. After you advised that the 12 code is all ok, I had to question whether either the front power switch is bad, or if the front key lock is on. I was able to find an old Mitsubishi (27" Tube) TV remote to try as I have no manuals, remote, or history about this one. The old remote powered this set on immediately. It appears to be working just fine. The old remote doesn't have some of the buttons that are needed to navigate the menus in the TV but my point it,, THE TV IS ON AND WORKING! .. Matt, I can't thank you enough for your input, it made me dig more into the obvious first. I do have two more questions for you though. First, would you have any Mistu remotes around that I could purchase from you? and How do I get this front screen to hang onto the clips flush w/o bowing out in places? Again, thank you, that all clear code was just what I needed. Chris
