TonyG
Jan 30, 2005, 12:08 AM
Post #3 of 7
(1493 views)
Re: [mel] Mitsubishi CS-35201: Intermittent Sound
Hello Mel, Thanks for the suggestions. There are two voltage test points in the audio section, 12VDC and 20VDC. Do you think one of those was B+? Both voltages are stable with or without sound. I tried resoldering any connection that looked less than perfect but the problem persists. I could only locate R761 and it's connections were good and the component did not look toasted. In addition to a step function cut out, the sound now occasionally gets raspy before dropping out, and sometimes comes back in at "half" volume and jumps to full volume for a few seconds before dropping out again. I feel blind without a schematic. Do you know where I could get a copy of the audio portion of this TV's schematic? Thanks, Tony
