hunter636363
Oct 19, 2011, 6:59 PM
Post #1 of 9
(55570 views)
Mitsubishi WD-60737 DLP with sound but no picture - Changed lamp & Ballast
I have a Mitsubishi WD-60737 DLP with sound but no picture. (Red light on front panel) I replaced the lamp (original one was blown w/ glass all inside of it) & the screen came on the first time I started it & the tv worked fine, but the next time I went to start it, sound came on but no picture for a few minutes, & then the tv shut off & the red light came back on & the screen/lamp would not start up - The new Mitsubishi lamp is still good, so I researched on the internet & it said to try changing the ballast, which powers the lamp - I ordered the correct ballast & installed it, but this did not fix the problem & the issue remains...Red light on front panel after a few minutes, tv has sound but no picture. (Occasionally when you try to turn it on, there is no sound & no picture, & one time it came on just fine for whatever reason & worked perfect, but did not work again once we shut it off) I have tried resetting it many times, but the problem remains. Could it possibly be the main power supply? Any help at this point would be greatly appreciated! Thanks a million for you help! Kevin
(This post was edited by hunter636363 on Oct 19, 2011, 11:05 PM)
