RCA27120WN
Feb 4, 2005, 5:11 AM
(1214 views)
More help needed! RCA help from you knowledgeable experts
OK, I haven't had much response to my questions and I need more troubleshooting things to try. I put a new fuse in and and it blew right away. I am waiting for a schematic to show me what the components are. Please add input if you can. The blown fuse wasn't completely black, but I did replace it only to have it blow immendiately when I plugged the set in. Could use a laundry list of things to check (and where to find them). Thanks Anyone? I have a RCA 27" (1992) model F27120WN, CTC167R that developed a problem in the last week. While on, the tv would click off by itself. I would try the on button and would only get a green light blinking on the front. 3 blinks and nothing else. I was able to "persuade" the tv to come back on by knocking on the case a couple of times. This worked for a few days and then the tv went off for good. No green light either. I opened up the case and found that the fuse was blown. Could this be it or is it probably something more. I plan on gettng a new fuse. Will radio shack have it or must I go elsewhere. In the meantime, anything else I should check? D
(This post was edited by RCA27120WN on Feb 5, 2005, 5:48 PM)
