1st;..
On the flyback , unsolder the wire that goes to the trippler from the flyback...
done
2nd..
Check the value of R523...
Comes off the emitter of T521...
Should read VERY low resistance..(0.12 ohms)..
Reads about 0.2 ohm
3rd...
Install the new transistor in the power supply..
done
4th...
Have your meter set to +DC volts on a range of 200 vdc & ready to go & hooked up to the anode of D514..
Use R523 for ground..
D514 comes off pin 15 or "L" of TR665 transformer..
5th...
With the meter hooked up as I said , turn the TV on & look for a quick pulse , OR better yet a steady +200 vdc..
6th...
Meter jumps to around 5V then back to zero when unit is plugged in.
Turning it on with the remote makes no difference.
