Sep 8, 2016, 6:06 AM
Post #2 of 5
(1785 views)
Re: [Scott1124] Need Help Aquos sharp losing sound
Finally got the model number correct, and some minor user name changing and some symptom modification. I still ask if it does same on any other inputs OF the TV? Taking audio from the TV's headphone jack and feeding it into a surround system still doesn't change the fact that you are using ONLY the satellite box as TV's signal source. (Unless you're taking audio from the satellite box, which would mean that it, NOT the TV has the problem. Prove to me and yourself that it does the same thing (or not) with a different source feeding a different input type on the television (a DVR feeding the Composite or component inputs, for example). ------------------------- Location: Far, Far Away
