Need a green crt for RCA 52" projection television
ronlj1
Jan 24, 2010, 8:34 PM
Post #1 of 39 (568 views)
Need a green crt for RCA 52" projection television Can't Post
I am looking for a green projection crt tube number H180BSB22 (G) for an RCA 52" model number P52750WKLGI and it is a 1993 model If anyone on the forum has one or know's where i can find one please let me know. Prefer a good used tube unless i can find a good price on a new one since I don't want to put that much money into it.
FUXER
Jan 26, 2010, 4:30 AM
Post #2 of 39 (552 views)
Re: [ronlj1] Need a green crt for RCA 52" projection television [In reply to] Can't Post
Not familiar with the make & model, but most tubes are the same- which means any of 3 could replace the faulty one. As to longevity of toobs- forget it!(They are run at extra hi EHT in futile attempt to get acceptable brite- so they don't last long!.).
Jan 26, 2010, 4:06 PM
Post #3 of 39 (546 views)
Re: [FUXER] Need a green crt for RCA 52" projection television [In reply to] Can't Post
FUXER;......
WHAT the HELL are you THINKING OR DRINKING ???
What kind of false & misleading to erronious BS is that ????...Unsure....
What do you mean by ""any of 3 could replace the faulty one.""???..Shocked....
Are you talking about the "red" replacing the green , or the "blue" replacing the green or another "green" replacing the green ???
IF you are talking about replacement CRTs in general , then that statement is an outright LIE !!!
In case you forgot , CRT basings ARE different & there ARE physical (mounting) differences etc as well....
Not only are you not familiar with his make & model , but you need a refresher course on CRT construction (physical) , Gun design & specs , operating voltages , basing connections etc......
IF you are not familiar with something , with all due respect , my advice would be "NO Comment"....
He's had this set since 1993 & he needs a CRT...
Lets do some math here...
2010-1993=17 years....Thats pretty dam good even by todays standards....& it's RCA !!!
IF you are taking medications , STOP!!!..Crazy.....
IF you are not , START !!!...Unsure......
ronlj1;....
Please consider what I said before you make a mistake....
To be safe & sure GET the original type ONLY !!! ....
GOOD LUCK....
Later...Ron.M....Cool....
Gus67
Jan 26, 2010, 9:39 PM
Post #4 of 39 (537 views)
Re: [Ron.M] Need a green crt for RCA 52" projection television [In reply to] Can't Post
Somehow my post ended up on the wrong thread
Anyway...
Looks like someone is on a rant again
SmileSmileSmileSmileSmileSmileSmileSmileSmileSmileSmileSmileSmile
FUXER
Jan 28, 2010, 3:48 AM
Post #5 of 39 (523 views)
The answer was meant to tell the OP that a green tube for his set was the same as a red tube or blue tube. Yes i know tubes- I,ll bet I,ve swapped far more tubes successfully than you. In Op,s case it seems he can't get a r/p orig tube- so i said a tube from an equivalent set would fit if the same design, mountings, size- BUT could be different make!. Now I am not going to get into a slanging match with you- I just can,t be bothered!. Do you really think that the OP is a dummy who wouldn't know what I was saying?. Take your medication for narcissitic personality!. AND stick your bold type up yer f@!^%ck%$n rse!!!.
Jan 28, 2010, 3:39 PM
Post #6 of 39 (517 views)
  FUXER:...
The answer was >> meant << to tell the OP that a green tube for his set was the same as a red tube or blue tube...yada , yada , yada...so i said a tube from an equivalent set would fit if the same design, mountings, size- BUT could be different make!.
Certain Tech's here (Myself included) think that some Op's expect us to be psychics & know model #s etc when they post for a problem.....
You are the FIRST one here that I've found that expects the OP to be psychic !!!!...
NOWHERE in your 1st post do you explain OR say ANY of the above....
& WHY even mean to tell him that the red & blue are the same as the green when he makes it PERFECTLY CLEAR that he needs a
GREEN CRT ????
ANYBODY that has any brains in this trade should know that the 3 CRTs in any CRT type Projection TV are the same except for phosphor color...
Now I am not going to get into a slanging match with you- I just can,t be bothered.
When you post that kind of an answer in a thread I run across , you'll get one , like it or not...ACCURACY , ACCURACY COUNTS !!!
NO , but your answer indicates you might be ...
Do you know him personally ??? ...
Unless you do , you should give him the benefit of a doubt....
People like you who CAN'T back up their statements with fact , resort to name calling & cursing....
Anybody who reads this far into the thread need only to back up 3 posts to see what a LIAR you are....
Shows what a low class talent you are...
Special , just for you FUXER;....
Later ????....Ron.M....Cool....
Gus67
Jan 28, 2010, 10:44 PM
Post #7 of 39 (507 views)
Ron,
Were you not loved as a child,why the hell are you so bitter?
Fuxer appears to me to also know a thing or 2 about tv's why the hell do you want to trash him?
In the electronics field I work in, the senior guy is usualy someone who not only has vast electronics experience, but also usualy someone who gives guidance and fatherly advice.
I have worked under 2 Engineers in the past 20 years.These men were not only absolutely brilliant in their electronics knowlege but world class,stand up,solid men.They would not only give you the answer,but take the time to explain it to you and help you understand it.They never "brow beat" or talked down to myself,or anyone else who they worked with on any project,no matter how important or how urgent of a deadline.It appears to me you have not been so lucky to work with people like that.
Before you trivialize my 2 mentors.I want to tell you both of them are probably far more successful than anyone you would ever know.One started the USA division of the company I work at and the other was a retired Electronics Proffesor for an Ivy league University in New England.I do not want to say what one,but it's a well respected and well know school.
I hope you can read this and take something from it.You do not have to knock people down to proove your knowledge.Be a man and let it stand for itself.If people do not respect you then so be it.
I took the time to write this because I feel you have the potential to be one of these guys...don't be so angry.Life is too short.Smile
FUXER
Jan 29, 2010, 4:53 AM
Post #8 of 39 (499 views)
Thank you SOOO much for your good wishes Mr RON- I am having trouble breathing because of the watery/ pooey hell you designated me to- but what goes around comes around- so you may be assured that YOU are designated for the same fate- goodbye- creep!!!.
Jan 29, 2010, 3:14 PM
Post #9 of 39 (494 views)
Re: [Gus67] Need a green crt for RCA 52" projection television [In reply to] Can't Post
Gus67;...
Listen , you dipstick , FUXER gave a INACCURATE & misleading answer to someone looking for a CRT...I'm trying to correct him &straighten his butt out....Unsure....
Correct , he appears to be knowledgeable , so why give that type of an answer...
In the electronics field I work in, the senior guy is usualy someone who not only has vast electronics experience, but also usualy someone who gives guidance and fatherly advice. yada , yada , yada...They would not only give you the answer,but take the time to explain it to you and help you understand it.
You should be directing those statements towards FUXER !!!!!
NOT ME !!!! .....
Before you trivialize my 2 mentors..
I could care less that you even have mentors...
Gus69;....
You've given me problems in the past....
You do NOT have a dog in this fight....
This is between FUKER & me....
If you can possibly understand English & READ the OP's post & FUXER's answer & more importantly understood both , you wouldn't have posted your dribble about your 2 mentors (??)....etc...
Do NOT try to cajole me in ANY way...
Do NOT continue to stalk me & comment to me on these threads or you WILL have a problem....
In other words , I told you that I would avoid & not comment to you , now you do the same for me...
If you think I'm kidding , try me...I'm ready...
Let's part as enemies & leave it at that....
.......Ron.M.....Cool....
Gus67
Jan 30, 2010, 12:58 AM
Post #10 of 39 (482 views)
Ron,
Go gets some mental help.You really need it.
You either attack someone because you disagree with their opinion,or you tell them they are not qualified to do something.
I was feeling bad about busting you balls and was trying to give you a little advice.However,it's obvious you are way beyond that.You, are truly in need of psychiatric assistance.I sleep a little uneasier knowing there are people like you out there roaming free among society.
You should also realize I only comment on you when you do something crazy...did you not notice that I have not made a comment on the sound and friendly advice you gave?
Like I said in the past.I do not like your behavior.You are rude,condescending and arrogant.I am actually suprised the moderator of this forum puts up with it.I will continue to bust your balls because you feel you can tell me what I can and cant do.I have taken you up as my pet project...I will comment on all of your irrational behavior untill I tire of it.
Of course,I would stop if you apologized to everyone you have insulted.
You cannot go through life insulting and demoralizing people because you feel you are superior to them.One of them could be a person (like myself)...who will relentlessly bust your balls until you cannot take it anymore.
Well...what do you have to say?
denonjapan
Jan 30, 2010, 1:19 AM
Post #11 of 39 (480 views)
sO finally somebody called you a POOEY and that's exactly going through your retardicity in hell. what's wrong with you is> you do exactly by the old book and I sensed most of your tactics are identifying parts by parts so you will have a good conversation with anyone but without a good result or terminology as repaired. why all these effort of nonsense? I mean! no issues you started has good end result. All of them are balogna!!!!!
QUOTED: "The answer was meant to tell the OP that a green tube for his set was the same as a red tube or blue tube. Yes i know tubes- I,ll bet I,ve swapped far more tubes successfully than you. In Op,s case it seems he can't get a r/p orig tube- so i said a tube from an equivalent set would fit if the same design, mountings, size- BUT could be different make!. >>>>>>
HELLOOOOOOO! Any original parts , once used with the new or different model. the part nos changes but the specs still remains. i said this long time ago. no BUT'S as far as mounting size is concerned.
Accuracy counts for exact model, nobody expects nobody to be psychic unless your re-search capability are beyond accurate, that what's count the most. it seems, there is one individual here in hiding, and he's right!!!You just have to have the balls tweaking parts accordingly. Not necessarily by the book or part nos but by specs. Projection tubes don't last long, Replacing them doesn't bring back the original performance, no matter what or how.. they just don't! do you know why? Talent is what makes good engineering, you don't speak them openly.....LOL!
denonjapan
made in japan
Gus67
Jan 30, 2010, 9:33 AM
Post #12 of 39 (476 views)
Re: [denonjapan] Need a green crt for RCA 52" projection television [In reply to] Can't Post
Come to think of it,this denonjapan guy is right.I have really not seen any of your help end in actualy repairing something.I was having trouble understanding his post cause of the obvious language barrier..but I think he's trying to say...
"You talk a good game but have not really ended up with any results as far as I can see"
I agree with him.
I originaly was pleased to find someone who seem to be able to troubleshoot and guide me in an area that I was unfarmiliar with.But now,I realize all of your information was dribble and fluff.You make stuff sound more difficult and comlex so you can appear to be inteligent.
Ron...you are just full of hot air...you are also a miserable person.Stop insulting people and I will leave you alone.
Jan 30, 2010, 5:35 PM
Post #13 of 39 (335 views)
Gus69;....
Between your 2 posts & that WHACKO "denonchina" , there's WAY too much BS to reply to...
So I'm going to pick out parts of your post & WHACKO's....
Gus69;=>
Post #10;=>
LIE !!! Go try to find one....WRONG !!! ...I try to correct someone if they are giving misinformation , bad advice or just plain insulting commentary , such as , well you know....Like you do....
Another LIE....
See;=>
http://www.tv-forums.com/...cgi?post=64564#64564
http://www.tv-forums.com/...cgi?post=64562#64562
I have no clue what this one is about.!!!!
http://www.tv-forums.com/...cgi?post=64563#64563
http://www.tv-forums.com/...cgi?post=63208#63208
http://www.tv-forums.com/...cgi?post=63062#63062
That's enough of that....
I don't need comments from you , of all people , on my "sound & friendly" advice....
Thanks , but , NO thanks....
Like I said in the past.I do not like your behavior.You are rude,condescending and arrogant.yada,yada,yada....
GEE , dad, can I come out of my room now ???
KISS MY GRITS !!!!
!1st off , I haven't demoralized anyone. PERIOD......
2nd...I haven't insulted anyone , including you , who didn't deserve it...
You are another person that lets a skull busting egotistical attitude get in the way of constructive criticism.....Remember , now , I CAN prove that....
3rd....I feel superior to no one...I feel inferior to no one also...PERIOD....
See;=>..
Sometimes I come across angry..it's a gift of mine,unfortunatly I also look angry in person as well,but I am "" really a fun guy""<< yeah , riiiiigghhhttt !!! ..misunderstood both verbaly,visualy and in written form. << Awww , what a shame !! You have to know me to understand.My wife always laughs at me when I get involved in these forums..she always asks..who did you p**s off now? It's always someone...everytime... <<< Yup , yup.....
Nuff said....
denonchina;==>
Waaaay too much BS & misinformation to comment on here...
Besides , I'm not in the mood to write a book...
Gus69;=>
Post #12;=>
I agree with him.
OK , NOW I know what part of the coo coo clock you reside in...
1st;=>...FACT;... "denonchina" was banned from this website for 30 days due to seriously bad behavior....
2nd;=>...Go check a whole bunch of his posts & see how many if any are "sound & friendly" advice....
3rd;=>...FACT;... This person & NOT me , needs serious psyciatric help...Check some of his posts...I got some real beauties for you to see...& "language barrier" makes no difference when it comes to his mental state...
4th;=>...You fixed your TV ALL by yourself without ANY help from me...Riiiiight....
OK....Let the games begin !!!!
OR;
?????....Ron.M.....Cool.....
Jan 30, 2010, 10:27 PM
Post #14 of 39 (324 views)
I thought he passed...
THEN:
NOW:
http://www.tv-forums.com/...ackson%20dead;#50203
Any unfamiliar expressions/terms - try googling them.
Jan 30, 2010, 10:56 PM
Post #15 of 39 (321 views)
Re: [jts1957] Need a green crt for RCA 52" projection television [In reply to] Can't Post
jts1957;....
Got a good laugh outta that...But....
For the life of me , I can't figure out how any of that applies to this thread....
Unless , it ^^^has to do with "dxxxxxx"....
Later....Ron.M....Cool....
Jan 31, 2010, 12:44 AM
Post #16 of 39 (317 views)
Michael Jackson was aka Wacko ("Whacko") Jacko.Cool
Gus67
Jan 31, 2010, 1:30 AM
Post #17 of 39 (314 views)
Ron,
You are a mental case... you are really nuts.
The real funny thing is you feel that that tv in my sun room would not be functioning without you input.Do you realize there are dozens of posts on this forum about coolant change that you were no part of...
Do you also realize that Phillips had a team of Engineers designing that televisions?(that is the brand tv that started all of this for all of you people new to this rant)
has any of these guy's called you and asked your input on how to design them?
Beileve it or not...people fix tv's all over the world without your knowlege or input..hard to believe,huh?
I also do not see anyone coming to your defense...Your delivery of information is driven by your obsession to be the one with the answers.You are the man...the hero of the television community.That is,in your own mind of course.
I bet you live alone in a trailer park with a bunch of cats wondering why your wife left you and your children do not talk to you
am I right?
you bet I am.
Your personality and you people skills fit that profile.Giving advice on this forum is the only thing you feel you are in control of.
I could go on and on...but what's the use? I will wait untill you act like an arrogant a**hole,and then I will continue.It may be tomorrow,it may be next month...but I will be there.
You also said the japanse guy was banned for a month for bad behavior.(again,attacking someone for no good reason)
Maybe the moderator will ban me for speaking my mind about you?...oh wait,I bet he/she probably agrees that you are a little off your rocker as well.
denonjapan
Jan 31, 2010, 3:08 AM
Post #18 of 39 (308 views)
RON!> I think that didn't answer the original question about you giving repair advices and end up to nothing wasn't it?..instead, you created another lie bout me being suspended for 30 days? where is that coming from???SlySlySlySly.......I can't be in the net everyday like you while i have transactions, and places to deal with?.
RON! you good of analizing things, and hearing you and how you manipulate individual with hopes and promises are now coming back at your oldass. why not try going outside with your wheelchair sometimes!.. LOL ...How far could you venture out of your monthly pension besides the internet, washroom and masturbation? SlySlySlySly
Your quote "2nd;=>...Go check a whole bunch of his posts & see how many if any are "sound & friendly" advice.... > This is often mistaken me being unfriendly for telling the truth or me pretending to be nice like you lying on everyone, presuming you had a pleasant but deceitful conversation, which one?????? You see! I don't do tricks! I will tell you right from the beginning. Either you honor it or not, im not trying to befriend to no one. There are no serious issues here as if you often took being dimmoralized or attacked. This is nothing but business and remember! i wouldn't be where i am today if follow thru what you thought everyone should....too bad, you couldn't turn back your time...And please explain me one thing? Let's pretend (yeah riggght!) me having this language barrier or mental state. Why all your lifetime you're down there and im UP HERE?....Is that fair?......I still look at you as electronics recycle bin. mama la verga pendejo!!!!!!!!!!!!!!
denonjapan
made in japan
FUXER
Jan 31, 2010, 4:30 AM
Post #19 of 39 (306 views)
A normal person like me only has to look at your avatar to realise you are a f#@$%K*&g complete & utter weirdo= not to mention psycho- and also that you get your "kicks" from belittling other people with FAR more experience than you. Fact- any tube can be used in any position in a projection tv. The colours may be incorrect- but so what- we are only interested in confirming operation of relevant sections ok in the 1st instance. tHE TOOBS USED in proj are run at x-ray voltage- is that where you lost your knackers?- & because of this toobs quickly go low emission- quick test is to sub tube to see if worth going further- usually not- but point is proved. Incidentally, down here in the toilet/sewer you kindly consigned me to, there are many plasma/lcd sets- boy- they stink!. I am getting out soon- and I am very confident that YOU- yes YOU Effwit- will be consigned here for eternity!!!.
Gus67
Jan 31, 2010, 10:59 AM
Post #20 of 39 (301 views)
Ron,
It looks to me that I am not alone in this belief that you are an a**hole.
Sorry..
Why don't you try to improve your people skills and maybe people will like you a little more
Jan 31, 2010, 4:11 PM
Post #21 of 39 (284 views)
Get ready folks , this IS going to be a LONG post....Mad.....
Gus69;....Mad...
My friends think not....You (enemy) are the exception....
Absolute HORSEPUCKY !!!!...I think I helped , but you think you did it ALL by yourself...Dream on...
Do you also realize that Phillips had a team of Engineers designing that televisions?...
What an intelligent statement that among others you make....< Sarcastic , YES...Your statement truthful, NO....You must think I'm really naive....
See above....
He/she has better things to do than watch an idiot like you go after me....
The rest of your post is worthless dribble not worth commenting on....
Proof coming up....
denonchina;.....
You asked for it , here's proof;....
From PM;....
(Sender's name deleted for privacy & security reasons)
Sorry Ron,
I missed the message sent on 14/11
I have just reviewed your message and banned denonjapan from the forums those posts are in for 30 days with a ban message "banned for insulting other members"
If this doesnt get the desired behaviour please let me know and I will take further steps.
Admin
Now the cat's (sorry jts1957 , just a figure of speech) out of the bag.... denon , who is lying now ????
Gus;...I NEVER LIE especially about something as serious as this....PERIOD !!!
denon..As far as repairs go , how MANY have you given solid GENUINE assistance to that WORKED ??? ....
That's a cop out excuse for your 30 day ban....
Your mental state is already undeniably certified as WHACKO....
You know nothing about my lifetime nor where I'm at...I WILL tell you that you ARE 100% WRONG about my location in life....Fantasize all you want , you get nowhere....
FUKER:...
You need to get better glasses...My avatar (At least I have one , where's YOURS ????) is representive of a senior citizen wearing glasses....NOTHING weird about that....In your possibly perverted mind , maybe....
The issue over the Proj CRT swapping is a dead horse I refuse to beat...Too late for you to TRY to justify your lousy earlier post....
Gus;.....
denon is a mental midget & FUKER & I have had issues....
You , on the other hand are an instigater that delights himself with inciting others....Go on your merry little way & leave me alone....
Gus , FUXER & denon;....
The
bottom line here is this;....
I AM here to stay....
NOTHING you say will change that....
This is a TV FORUM & NOT a blog !!!!
I came here to help people....
IF I see a "stupid" reply or misinformation , it behooves me to say something & correct it....
I do it in a straight forward way , no beating around the bush...
This does not thankfully happen very often....
If you take it personal , it's YOUR problem & NOT mine....
If you wish to continue this name calling , etc , I may or may not partake in this further....
Have a ROTTEN day & WEEKEND !!!!!
?????.....Ron.M....Cool.....
(This post was edited by Ron.M on Jan 31, 2010, 4:11 PM)
Gus67
Feb 1, 2010, 12:31 AM
Post #22 of 39 (271 views)
All I can do is laugh...
two other people jump in to this thread to trash you, and you attempt to manipulate the thread to appear as if all of us are wrong.
I will continue to watch and comment where I see fit.
Feb 1, 2010, 3:06 PM
Post #23 of 39 (261 views)
Gus69;....STUFF IT !!!!
FUXER
Feb 2, 2010, 4:01 AM
Post #24 of 39 (250 views)
Vteran & retired tv tecnician- we only have your post to say this- my feeling is utter boolpoo- & HW DARE YOU CALL ME FUKER!!!- my name is FUXER!!!. Let us imagine- those readers with SOME intelligence- which are everyone BUT you!!- If you thought there was an error in a post by an experienced tech- YOU are not in any position to do anything about it- it is up to the admin to do so- & same person would say something like" feel you are wrong here- please edit your post"- compre- PHUCKWIT?!!!!!>.
Gus67
Feb 2, 2010, 10:20 AM
Post #25 of 39 (244 views)
FUXER,
I believe we are not dealing with a normal person here.Most people say things like...please..thank you...etc.
You know,manners that were taught to you as a child.
Instead he decides to shove his beliefs down your throat.If you do not listen,you are stupid,if you don't understand you are not qualified.
Most of his posts end saying either you are not qualified, so do not attempt to do it,or the problem goes unsolved.Either way he paints a picture of himself being knowledgeable.
He does know a thing or two about television..I will not take that away.However his people skills and troubleshooting technique are the worst I have ever seen.
Search for (options) Web Design by Web Ideas - Page loaded in: 0.34 s on (CGI/1.1)
