riverdale
Feb 12, 2005, 11:31 PM
(1130 views)
Need help on splitter asap--THANKS
Ok, here is the deal. I went to replace the hv splitter on my Zenith projection tv, but there seems to be a slight difference between the two of them. When you buy it new, the assembly comes with the high voltage splitter and the focus block asssembly. My focus block has four wires coming out of the screen side of it , and the new one only has three. The wire it is missing is a green one out of each screen pot. They all tie together, and run to my power supply to a connector labeled DF.. The other difference is on the splitter itself, mine does not have a red wire coming out of it like the replacement one does. besides some connector difference, everything else is the same. I am just needing to know if i can still use this one or what??---Thanks ahead for all the input. The part numbers are as follows:: Original one: a-17196-05 Replacement one: a-17196-06
