chrisjmatheis
Sep 5, 2015, 2:30 AM
Post #1 of 10
(4198 views)
Need some help troubleshooting circuit
Hello everybody! I have recently tried my hand at fixing flat screen TV's and have been pretty successful or probably just lucky :-) But now I have one that is giving me a hard time but I have isolated it as far as I can and could use a point in the right direction. So I will give you a run down of what I did and where I am at. Model LG 47LN5700-UH LED TV that was given to me Take it home, plug it in, standby light comes on, press power button on TV, LG splash screen appears, goes black, shine flashlight at screen, press menu button on TV, menu appears, unplug, take off back, note: power supply and LED driver on same board, remove power supply from TV. Input: 120VAC Output: 3.5V, 12V, 24V LED Driver Output: 100V, 111V Note has a 4 pin connector for two separate outputs P201: GND GND 12V N.C. (not sure what this is) 12V 12V GND GND 24V 24V GND GND 3.5V PDMI2 3.5V PDMI1 PWR-ON DRV-ON Check standby voltages of 3.5 OK, closed 3.5V to PWR-ON circuit, 12V and 24V rails OK, closed 3.5V to DRV-ON and got 76V at LED driver output, closed 12V to PDM1 and another 12V rail to PDMI2, LED output over 150V and then drains to 76V. This is where I need help, I don't know where to go next, it seems as the circuit is overloading itself. I can solder and can use multimeter and have both, there are no bad caps, have checked some diodes on the board - in and out of circuit, checked all transformers for continuity on the primary and secondary sides, and definitely checked all fuses. Any help would be appreciated and am comfortable with most component level repairs. I would really like to fix the board as I know that it is the problem but I have a line on another one and they are plentiful and I have plenty of TV's so this is a challenge that I would like to conquer) If there is any more information you need please feel free to contact me and I hope I was specific enough without sounding like too much of a NOOB.
