BL_Thompson
TV Repair Authority
Feb 26, 2003, 11:08 PM
Post #4 of 4
(3214 views)
Re: [nickm] No Power to RCA F19204WT TV
Ok guys, this is the best I can do. The F19204 is a TX86 chassis circa 1995. Unfortunately, the service data is only available on paper. I only have CD-ROM based literature. I tried to find the HOT location number using Parts Finder, but it's apparently not listed... at least I couldn't find it. The HOT will be located near the flyback transformer (that's the device with the thick red lead going to the picture tube). It will be mounted on a heat sink, will have 3 legs, and should have a number stamped on it beginning with 2SC, 2SD, or possibly BU. You can check the HOT for a short with a DMM... most modern meters have a diode check function... use that. A short read between the base and emitter is normal. What you are looking for is a short emitter to collector. Hope this helps... ----------------------- Bryan Thompson Spyder Byte Services Albuquerque, NM
