BL_Thompson
TV Repair Authority
Feb 20, 2003, 5:46 PM
Post #4 of 6
(1057 views)
Re: [Guest] Panasonic 36" flat screen will not turn on.
I have no common problem data on that model, but I can tell you it's a complex chassis. Even though you know electronics, if you have no experience with TV's I would recommend taking it to a qualified professional. You could not only hurt the TV, you could hurt yourself! Did you know that 32" picture tubes run at about 30KV? That potential is present even when the set is unplugged. If you insist, you could check the line fuse. If it's not blown, please have the TV serviced. ----------------------- Bryan Thompson Spyder Byte Services Albuquerque, NM
