Jul 3, 2009, 2:32 AM
Post #29 of 33
(842 views)
Re: [Ron.M] Philips 21pt6341- tunes only one channel
RRRoobhore:.... ENOUGH IS ENOUGH!!!! Now you called my post "hogwash" Sure you went back and edited that out but guess what, my post was correct.
I put it back!!!...Yes ,if you read my post I said you were in the right area!!! But to shout "HOGWASH" is designed to create anger so your protest is false. IF you went back & read the post that was in, YOU would see that "Hogwash" reffers to the "PANEL" YOU said the micro was on... I diagnosed the guy knew how, you were fddling about with poor reception. Now you are a psycic????...Horsepucky!!!.... You found out the SAME time I did....You trying to impress people here???? I again repeat I agreed not to bother you if you didnt bother me YOU started it. What a FULL LOAD OF S%$T THAT IS!!!!.... Read the following;==> rrobor Veteran Jun 30, 2009, 10:23 PM Post #7 of 28 (100 views) Copy Shortcut Re: [Ron.M] Philips 21pt6341- tunes only one channel [In reply to] Quote | Reply Ron neither of us will ever find out because the chances of this being fixed is close to zero. As a Philips engineer for 24 or so years I know what issues they had and this sounds like the usual. So yes it may be hogwash to you if that pleases you. But whether the micro is on a panel or not they were famed for doing just the thing the guy complains of, so tell him after he spends his money and finds out. sure it could be anything but Id be willing to bet on it, would you. PROOF YOU ARE A LIAR AGAIN!!!! Now to suggest that the timing crystal on the micro is not a micro fault is trying hard for an excuse. I NEVER suggested that... I said THE MICRO WAS NOT AT FAULT that YOU said ""used to cost heaps to get it unscrambled and you had to send the panel to the distributer to have it done.""...YOU & ONLY YOU JUMPED THE GUN...PERIOD Now you call me a pest. How high would you jump if I called you the pest for patching and pasting and pointing out ad infinitum, and totally comandeering any post that suits your mood. Calling you a "pest" was a gentle jab & NOT intended to offend you.... Who's got "Thin skin" now??? Patching (in computer speak,that's called "Copying) & pasting is a way of life on the net,etc... Like it OR leave it!.... I do NOT& NEVER did comandeer ANY post OR thread..... I reply accurately with as much info as I think is needed.... You sir are a loud bully, I ask you to leave me alone and I will certainly leave you alone. THERE IS A GOD!!!! Your wish is hereby GRANTED.... Veteran & Retired TV technician
