kassy
Mar 29, 2005, 9:10 AM
Post #2 of 4
(1501 views)
Re: [fetharna] Philips 28 inch wide screen
First you have to check CRT.While TV works, conect for a short moment R gun to ground by wire.If CRT is OK entire screen have to glare in red colour.Don`t worry if TV switch off, it normaly because you open CRT full and beam current limiter will switch off the set.Switch the set on again and check G and B guns.They behaviour have to be similar like R gun.If it is not CRT have bad emission and TV set is for rubbish.If it is not, suspicious is micro controller like almost every Philips`s chassis A10.
