Apr 22, 2005, 9:19 PM
(1530 views)
Re: [Balance] Phillips Magnavox screen turns purple
The purple screen indicates that you are loosing the green component from your video. The problem could be in the green drive transistor or low emission from the green gun in the CRT. Magnovox CRTs are usually pretty reliable but from your description sounds like it may be the latter. You will need a CRT tester to find out for sure. Meanwhile, you might want to check out www.FreeFlatScreens.com/?r=10948674 for an oportunity to earn a free replacement for this set with a little effort on your part.
