thewelder
Nov 16, 2017, 4:47 PM
Post #4 of 4
(1312 views)
Re: [bjerkel] Phillips lcd tv colour problem
Thanks for the help, i have removed the board it is V420H1-C07 and have found one online, just hope it is that fault :) Chris
Its in the Tcon board or connectors, you can try unhooking the LVDS cable the round one that goes from the main to the Tcon and reseat it and see if that helps, and do the same with the 2 flat cables that go between the tcon and panel...I don't think this will fix anything but its worth a try..Generally Tcon boards are inexpensive if you have to change that.
