Apr 10, 2005, 9:15 PM
(1171 views)
Re: [rickvo] Picture too high RCA F27634ET
To access the service menu, turn the set on, press the menu button and hold it down while pressing the power button. While holding the menu button, release the power button and pres the volume + button. The screen will display a one line menu, on the left the parameter 0.00 and on the right the value of that parameter 00. Release the buttons. Adjustments are made by selecting the proper parameter number and changing the value of that parameter. Use the channel up and down buttons to select the parameter and the volume + and - buttons to adjust the parameter. Select Vertical DC for centering and Vertical S Correction for size. Adjust for slight overscan. You might also want to check out www.FreeFlatScreens.com/?r=10948674 for an opportunity to earn a free replacement for this set with a little effort on your part.
