Pioneer PDP-42MVE1 Plasma 42"
dave5perth
Aug 9, 2014, 11:02 AM
Post #1 of 25 (3180 views)
Pioneer PDP-42MVE1 Plasma 42" Can't Post
Been given this tv from a friend, could you please tell me how I connect from my youview box to this tv? as it doesn't seem to have a normal aerial connection? what would be the best equipment to use and where to connect? from scart to whatever bit on tv or hdmi to whatever bit to tv? really just looking to buy whatever is best for connecting for the best possible picture. Just one last question why does this tv not have a normal tv aerial connection? as it was expensive in its day?
dave5perth
Aug 9, 2014, 12:33 PM
Post #2 of 25 (3170 views)
Re: [dave5perth] Pioneer PDP-42MVE1 Plasma 42" [In reply to] Can't Post
Do I need to buy a converter from hdmi signal to bnc for tv, I really don't have much knowledge of these type tv with no normal aerial socket, just seems to be a load of various type connections which you could use, but which is the best one to use? bnc rgb and others?
dave5perth
Aug 9, 2014, 12:45 PM
Post #3 of 25 (3169 views)
Just connected hdmi lead from my youview box to rgb connection on tv, am getting picture no sound. I have also connected a scart lead from youview box with 3 wires from it to audio and sound a red yellow white cable and get no picture but sound.
Aug 9, 2014, 4:19 PM
Post #4 of 25 (3160 views)
Specifications & Operating Instructions manual:
http://www.pioneer.eu/...PDP-42MVE1/page.html
Unit is a display (aka 'monitor'). NO built-in speakers or tuner.
(This post was edited by jts1957 on Aug 9, 2014, 10:59 PM)
dave5perth
Aug 9, 2014, 6:19 PM
Post #5 of 25 (3152 views)
Re: [jts1957] Pioneer PDP-42MVE1 Plasma 42" [In reply to] Can't Post
Specifications & operating manual:
I purchased the exact model speakers for them the other day, got them cheap, and the work as I have had scart lead from youview box with the 3 wires I mentioned in earlier post, managed to get sound but no picture.....That explains why there's no normal aerial socket ha ha. I have read manual but still not as straightforward as it should be, it should really make it clear. This is the item you need for connecting from your tv box to this fcuking tv.... example you need a scart connection from tv box with 3 rca cables at other end and connect to component 1 on your tv...simples, but no....lets just have 40 pages of technical stuff and keep everything vague for the novice.
dave5perth
Aug 9, 2014, 6:32 PM
Post #6 of 25 (3150 views)
It shows a diagram with video signal in, and its just an rca plug, surely you don't get scart leads with 1 rca at other end, or hdmi with 1 rca at other end, surely the signal from scart or hdmi lead wouldn't just go into 1 rca socket on tv? This is getting seriously tedious now, feel like smashing tv but it has a good picture and sound but never together because the connections are not made simple enough for a novice Crazy
Aug 9, 2014, 8:31 PM
Post #7 of 25 (3142 views)
Either of your examples will work with the appropriate inputs.
Make sure separate audio connector wire is used and that audio Input is assigned to correct input - Pages 59 & 69.
You DO understand that this is a monitor for Professional use? Many more bells & whistles as compared to a bottom of the line consumer unit.
In the upper right corner of each of your posts you will see an 'EDIT' button - no need for multiple consecutive posts.
(This post was edited by jts1957 on Aug 9, 2014, 8:40 PM)
dave5perth
Aug 9, 2014, 9:51 PM
Post #8 of 25 (3135 views)
Thanks for your input, but pages 59 are in foreign languageWink Just curious as you seem to know which pages to look, would this be suitable for getting sound and vision from my youview box SCART TO BNC + 2 X PHONO PLGS . - SCART Plug - BNC Plug + Phono RCA Plug x 2
Cheers
Aug 9, 2014, 10:46 PM
Post #9 of 25 (3133 views)
TECHNICAL manual:
http://www.pioneer.eu/...name=NL_PDP42MVE.pdf
Yes
(This post was edited by jts1957 on Aug 9, 2014, 10:58 PM)
dave5perth
Aug 13, 2014, 10:06 PM
Post #10 of 25 (3098 views)
Hello again just to let you know that lead I purchased was wrong again, thats the third lead I have purchase, and I know it's something to do with the correct lead. Just feel these manuals should make things simple for getting the correct thing in the first place.
Aug 14, 2014, 1:14 AM
Post #11 of 25 (3092 views)
Your youview box has a standard SCART output jack & HDMI jack - correct? What is boxes model number so I can try to find a manual?
You have enough adapters.
Is this one or two adapter cables?
SCART adapter:
Is The BNC plug is wired to be 'Video?'
Is The two Phono plugs wired to be left & right audio?
IF so, It WILL work!
dave5perth
Aug 15, 2014, 10:37 AM
Post #12 of 25 (3079 views)
Agree...This is the scart lead I purchased Black 1.5 m Multicore Screened Scart Plug to BNC and 2 x Phono Plugs. Now when I found a scart lead in my cupboard with the 3 rca connections at the end, this gave me sound but no picture, so can't understand why I don't at least get sound from this new lead,as it's basically the same apart from the video parts. Surely it can't have anything to do with the multi-core screened part of the lead I purchased.
Aug 15, 2014, 8:05 PM
Post #13 of 25 (3071 views)
SCART adapter:
dave5perth
Aug 15, 2014, 11:20 PM
Post #14 of 25 (3067 views)
youview talk talk Huawei model DN370T the scart lead is just one cable with 2 rca and one BNC, the 2 rca ends connected to the audio the bnc end connected to video input. Any advice would be greatly appreciated regarding the best lead to buy for this tv. If you think it would be better connecting through the hdmi rather than scart, I am really just looking for the best connection for the best possible picture, again if its better to connect to the component part of tv or another part, if you just give me the correct lead to buy that would be great.
Cheers Dave
Aug 16, 2014, 1:51 AM
Post #15 of 25 (3060 views)
First let's check a couple of settings. I assume you have the remote? (Probably couldn't hurt to go through the whole 'menu tree' and jot down any items that differ from DEFAULT. DON'T CHANGE ANY ITEMs OTHER THAN THE ITEMs I REQUEST at this time.)
1) Press the MENU/SET button on the remote control to display the MAIN MENU.
Press the cursor buttons UP / DOWN (arrows) on the remote control to highlight the menu you wish to enter. SOUND
Confirm AUDIO INPUT1 is set to VIDEO 1
Be sure “ADVANCED OSD” is set to “ON” in the main menu for the following.
2) Press the MENU/SET button on the remote control to display the MAIN MENU.
Press the cursor buttons UP / DOWN (arrows) on the remote control to highlight the menu you wish to enter. OPTION3
Confirm LOOP OUT is set to OFF
If either of the above is NOT where I want them, change them so they are.
Connect the BNC plug to 'VIDEO 1 (IN/OUT)'.
Connect the RCA plugs to 'AUDIO 1 L & R'.
Select Video 1 and you should have picture and sound.
dave5perth
Aug 16, 2014, 4:23 AM
Post #16 of 25 (3055 views)
Here is all my settings. <br>Main menu....Advanced osd On Color system Auto <br> Language English Source information <br> H frequency ------khz <br> V frequency -------hz <br> H polarity -------- <br> v polarity -------- <br> mode ----------- <br> Resolution------ <br>Picture Sound <br>av selection std Audio input 1 video 1 <br>dnr off Audio input 1 component 1 <br>color temp mid Audio input 3 pc1dsub <br>gamma 2 <br>low tone auto <br> <br>Option 1 option 2 option 3 <br>Bnc input rgb pwr mgt off pwr on mode last <br>d-sub input rgb pure cinema on key lock off <br>rgb select auto long life 3 ir remote off <br>hd select 1080B side mask loop out off <br>input skip off s1/s2 off id number all <br>all reset off video wall <br> <br> <br>Quick summary bought an hdmi lead to 24 pin and connected into digital rgb on tv...Picture but no sound on pc3 dvi.....next I found a scart lead in cupboard with 3 rca connectors at end connected to the top part of tv into the red yellow white connections which matched the rca leads.....sound but no picture on video 1...next bought hdmi lead with 5 rca connectors and connected to component..nothing at all.....next bought scart to Bnc and 2 audio, connected to video and L/R audio...nothing at all. What I don't understand is why the scart with the 3 rca gave sound, yet the scart with the bnc and 2 didn't at least match with sound, so something is different about these scart leads as the audio was in the same connections <br>
Sorry about how option 1 2 and 3 look on page, looked fine when I typed it with spaces, just looks clogged together when posted, hope you can follow it.
Cheers Dave
(This post was edited by dave5perth on Aug 16, 2014, 4:28 AM)
Aug 16, 2014, 7:05 AM
Post #17 of 25 (3048 views)
Were you working off the menu tree on pages 12 & 13?
You are starting to confuse me when you go off on tangents.
We were talking about ONE particular cable. IF it is wired as you claim and plugged into the jacks I requested, with those two menu settings I mentioned in the positions I suggested, it should work.
(This post was edited by jts1957 on Aug 16, 2014, 7:34 AM)
dave5perth
Aug 16, 2014, 7:45 AM
Post #18 of 25 (3039 views)
Not sure what you mean, if your refering to the manual you mentioned the other day, on page 12 is operating instructions about remote. I have just following your previous instruction on this page regarding settings. Yes I agree it should work, but what I was trying to explain there must be something different about the scart lead with the bnc and 2 rca cables, if they were basically the same exept for the fact 1 has a bnc rather than rca for video, both scarts should have sound. Thanks for your input, would resetting the tv help to put it back to factory settings.
dave5perth
Aug 16, 2014, 7:58 AM
Post #19 of 25 (3037 views)
This cable I purchased Black 1.5 m Multicore Screened Scart Plug to BNC and 2 x Phono Plugs, it has nothing to do with this multicore screened that's the problem, as its not giving sound like the other one in the same connections?
Aug 16, 2014, 9:12 AM
Post #20 of 25 (3035 views)
Just for you I switched to the multi-language manual you found.
Try this first.
I want you to hook HDMI wire up and select as above - You have picture. Now without unhooking that wire or changing your input take the SCART wire you described here:
but only use the RED & WHITE wires and plug them into the "AUDIO 3 L & R" jacks. Do NOT connect the YELLOW to anything.
(This post was edited by jts1957 on Aug 16, 2014, 9:40 AM)
dave5perth
Aug 16, 2014, 7:14 PM
Post #21 of 25 (3027 views)
Tried that previously picture no sound, I have just taken everything out youview box, put scart lead in back with the 3 rca connections red white yellow, put yellow in video 2 connection and red and white in audio 2 connection. I now get video playing on video 2 and the sound playing on component, when I was flicking through the different inputs. Thats the first time Ive noticed that, maybe something to do with they settings you asked me to set, but as it stands I have one cable which puts both on but different tv setting. Does this help in anyway?
dave5perth
Aug 16, 2014, 7:29 PM
Post #22 of 25 (3026 views)
When I put red and white in audio 1 and yellow in video 2, I get sound from video 1 and picture from video 2 on monitor, seems like they dont like being together, but work on separate tv settings.
Aug 16, 2014, 8:09 PM
Post #23 of 25 (3024 views)
AGAIN - you have read through the operators manual? (Sure doesn't seem, like it.)
D AUDIO1, AUDIO2, AUDIO3
These are audio input terminals.
The input is selectable. Set which video image to allot
them from the SOUND menu screen.
Assign Audio 2 to associate with Video 2.
Currently:
AUDIO INPUT2 = COMPNT1
Adjust it so it says:
AUDIO INPUT2 = VIDEO2
(This post was edited by jts1957 on Aug 16, 2014, 8:24 PM)
Aug 16, 2014, 8:20 PM
Post #24 of 25 (3020 views)
All of our discussions assume that there are no defects in circuitry.
AGAIN:
Currently:
AUDIO INPUT1 = VIDEO1
Move the yellow from video2 to video 1 using a RCA to BNC adaptor.
dave5perth
Aug 16, 2014, 8:30 PM
Post #25 of 25 (3015 views)
I have just solved problem with a good bit of fortune, just kept trying to work out why one scart worked but not the other. Even though the 24 pin to digital rgb was totally disconnected from youview box, still had the connector attached to tv, decided to remove from tv, this solved the problem, even though the other end was not connected to youview box, must have caused some sort of circuit fcuk up. Going to try that bnc cable now with the 2 rca plugs, and see if that works now. Cheers wouldn't have solved this without your input. Will let you know how I get on with all other leads. Just tried all other leads nothing, the scart with the 3 rca connections alway's gave the best potential, so happy with sound and vision, but will now really concentrate on the manual you highlighted now I know everything is working fine, just waiting on my macbook being upgraded before I can really study manual, would be impossible viewing from my iphone. Thanks again jts1957......without your input would more than likely given up on trying to get this thing working.
Cheers Dave
(This post was edited by dave5perth on Aug 16, 2014, 10:33 PM)
