wrestlefan2
Jul 20, 2011, 3:05 PM
Post #1 of 9
(5120 views)
Please Help with my INSIGNIA NS-LCD26 TV...power board??
Hi, I was given an Insignia NS-LCD26 26" TV from a friend of mine that bought a new TV since she couldn't use this one correctly and already bought a replacement. Was told if I can fix this TV, I can keep it. Always had a CRT TV and never an LCD, so I'd love to fix it so I can keep and use it. Here is the issue at hand: I plug in the TV and press the power button on side of the TV (she lost the remote). I have to press it a little harder than normal to get the TV to come on. The TV takes roughly 2-5 seconds before it turns on. It's not plugged into cable yet, so I get a No Signal Error and then it goes to Snow. After about 5 seconds of the snow, the TV shuts off like it's going into standby/hibernate mode. I have to unplug the machine and plug i back in to get it to come back on, but the same issue happens (almost like I'm resetting a circuit breaker that keeps tripping) I fix computers so I thought it would be an easy fix so I opened it up and checked the power board and all the capacitors look good and read correctly. The Fuse is fine (nothing loose not rattling not cracked and tests working on a fuse tester), but the holder of the fuse concerns me, one pair of the metal holders is fine and shiny silver, the other side looks like it's rusted/corroded. I tried to used electronic cleaning fluid to removed the rust and got most of it off, but the unit is still doing the same thing. So I don't know if that rust is causing the problem or if it's the power cord itself or if I should just replace the power board all together (doesn't come with the power cord, but the board is only $42 after shipping at the cheapest place I can find). Could something else be wrong with it that I'm over looking? I'm not that good with soldering, but if I can get some advice on how to do it (if it'll be cheaper than a new board (if power board is issue)) So any help you can give me will be greatly appreciated. Thanks
(This post was edited by wrestlefan2 on Jul 20, 2011, 3:33 PM)
