crawdaddy
Feb 9, 2005, 5:40 PM
(1289 views)
Re: [mikewile] Power issue with RCA 60" Big Screen
If it's completely dead, I'd look first at the main filter capacitor in the power supply, it'll be the biggest one you see. It will be rated for 200-250 volts dc, 400-680 microfarads. With the set powered as normal, you should measure about 150-170 volts dc across this cap. In a 10 year old set, it's very possible for power supply caps, or other caps in the B+ circuits to dry out because of heat cycling over the years of normal use. I' m a little mystified as to the unit powering up by itself, or why the speakers were affected, but cranky capacitors can cause a wide variety of weird things to happen in the tv chassis. If it does turn out to be filter caps, it won't cost a lot to repair, provided doing so doesn't reveal a host of other troubles lying in wait...10 years is not a terribly long time for a tv, it's just a crap shoot as what else you may find...Good luck, let us know how you do......
