Problem with TV Toshiba 50L7335DG
preebi4
Feb 25, 2019, 1:49 PM
Post #1 of 10 (364 views)
Problem with TV Toshiba 50L7335DG Can't Post
Hello, I'am having trouble with TV Toshiba 50L7335DG. The tv turns on, backlights is starting but no picture. I think there is audio but not sure because cant test it. There is only noise like working but no input signal. The question is how to understand where is the problem - main board, t-con board or lcd panel. The power supply board seems to be working fine because all voltages are correct. Main board is 32L4300 rev 1.02a, t-con is v420hk1-cs5. I try to find schematics to check some control points but nothing came up ( maybe search wrong i dont know).
Thank You!
preebi4
Mar 20, 2019, 12:28 PM
Post #2 of 10 (301 views)
Re: [preebi4] Problem with TV Toshiba 50L7335DG [In reply to] Can't Post
Replaced the t-con board and nothing. How can i check the lcd panel whether working or not ?
Mar 23, 2019, 9:59 AM
Post #3 of 10 (284 views)
If you can apply an audio input and correctly select the inputted audio, would tend to prove the Main & Panel = OK
preebi4
Apr 3, 2019, 12:38 PM
Post #4 of 10 (244 views)
Re: [jts1957] Problem with TV Toshiba 50L7335DG [In reply to] Can't Post
I connected an audio source to AV input on tv and with headset ( because speakers are disconnected ) but didnt get anything.... Tried with the remote to select different sources but no luck. There is some popping sound from time to time but no audio at all. Optical jack is glowing in red, there is some green led flashing in the middle of the board but nothing... I dont know what to do more. I guess will put it away
arizanotlari
Apr 5, 2019, 11:49 AM
Post #5 of 10 (230 views)
Hello.
http://www.dl.toshiba.com/tsb-dtv/NA/GB/EN/40L6353RK.html downland firmware and install.
check tcon supply (5v or 12v)
be sure backlight is working. i wait your answers.
preebi4
Apr 8, 2019, 6:10 AM
Post #6 of 10 (215 views)
Re: [arizanotlari] Problem with TV Toshiba 50L7335DG [In reply to] Can't Post
http://prntscr.com/n8ww67
This is the voltages on t-con. How to install this firmware with no picture ?
arizanotlari
Apr 8, 2019, 2:33 PM
Post #7 of 10 (211 views)
http://fget.dl.toshiba.com/...tion_Instraction.pdf
(This post was edited by arizanotlari on Apr 8, 2019, 2:34 PM)
preebi4
Apr 9, 2019, 5:35 AM
Post #8 of 10 (206 views)
Yes i saw the instructions thats why asking .....
http://prntscr.com/n9edmk
arizanotlari
Apr 9, 2019, 6:17 PM
Post #9 of 10 (203 views)
If usb stick led is blinking, upgrade successful : check lvsd lines on mb and tcon.
If usb stick led is not blinking, upgrade failed : mainboard is not working correctly.
Sorry my english Blush
preebi4
Apr 10, 2019, 6:44 AM
Post #10 of 10 (184 views)
in the begining usb flashes but after that ( about 1 min ) starts glowing constantly and the green led at MB starts flashing 3 times
Search for (options) - Page loaded in: 0.24 s on (CGI/1.1)
