Oct 29, 2004, 11:10 PM
(1088 views)
Re: [steering] RCA 25" model:27GT600 burning horiz output
I strongly suspect a bad flyback transformer which RCA has a reputation for. Before you go there, however, check the solder joints around the horzontal circuit, especially the horizontal drive transformer. Unless you have the proper test equipment, there is no way to test the flyback without replacing it. You might want to check out www.FreeFlatScreens.com/default.aspx?referer=7509165 for an opportunity to earn a free replacement for this set with a little effort on your part.
