pabrol
Feb 14, 2005, 6:48 AM
(1082 views)
RCA 52 inch runs but has no picture
Hi All, I have a 52 " RCA TV (MODEL - P52927) - It had problems of intermittent shut down - as in, it used to play fine sometimes and other times it used to just not start up, usually giving up after 3 attempts( clicking sounds ). It would fire up the screen would begin to appear and itw ould shut down. SO I started reading and reached the conclusion that it could be a HV splitter problem. Now there are 2 wires ( pink/red in color) at the back next to the power cable - one of which is the IHVT that goes to the HV splitter block and the other one I am not sure where it goes. Anyways, I managed to( foolishly) pull out the other wire from both ends and am holding it in my hand not knowing what to do. Can anyone tell me what I should do next. Where does this wire go to and how do I fix it? Next, how do I solve the problem of intermitten sartup and shutdown( It usually plays for a while before starting to behave badly). Thanks a ton, and hope to get some directions.
