Guest
Unregistered User
Jan 30, 2003, 6:34 PM
Post #1 of 3
(847 views)
I was given this set because a friend busted off the coax nipple on it. After putting it back together (he had a couple beers in em' and thought he would play tech ) the screen is bowed in the middle. I assumed there was a bad solder joint after all the traveling it was put through and proceeded to touch it up. I assume now the eeprom is corrupted. Could anybody verify that this may be true and if it is where can i get another or is it possible to reflash with default code? And if it is where could I find the code? Thanks!
