RCA F27732SB TV Blows Fuse
TVRE
Feb 11, 2008, 8:35 PM
Post #1 of 7 (185 views)
RCA F27732SB TV Blows Fuse Can't Post
Hi everyone,
I have recently encountered a problem with my RCA 27" TV. The TV blows the fuse every time it is plugged in. I am unable to do voltage tests as there is NO power. I believe the problem is within the first few components (filter capacitor, diodes, chopper transistor, etc).
Can someone direct me to the right direction of which are the most likely failed components?
Thank you
P.S. THE CHASSIS IS: CTC169CK5
stan31
Feb 12, 2008, 3:30 PM
Post #2 of 7 (175 views)
Re: [TVRE] RCA F27732SB TV Blows Fuse [In reply to] Can't Post
sounds like a shorted l are more diode in l v power supply
Feb 12, 2008, 3:45 PM
Post #3 of 7 (172 views)
I do not have a schematic for that specific model but I believe the problem would be one of CR4001 thru CR4004 is shorted.
TVRE
Feb 12, 2008, 7:29 PM
Post #4 of 7 (164 views)
Re:RCA F27732SB TV Blows Fuse [In reply to] Can't Post
Ok
I have tested all 4 rectifier diodes and I get forward voltage drop for all 4 diodes. That included 2 reading for each diode. I guess I have all 4 diodes shorted.
tvbrian
Feb 14, 2008, 6:21 PM
Post #5 of 7 (149 views)
Re: [TVRE] Re:RCA F27732SB TV Blows Fuse [In reply to] Can't Post
have you removed the degaussing thermistor , they sometimes break up inside and go s/c hence fuse bang
Franky
Feb 14, 2008, 7:54 PM
Post #6 of 7 (144 views)
Re: [stan31] RCA F27732SB TV Blows Fuse [In reply to] Can't Post
CHECK/REPLACE F4001 AND C4007 CHECK/REPLACE Q4101 (P/N# 200165) AND U4101 (P/N# 200419)
TVRE
Feb 15, 2008, 7:55 PM
Post #7 of 7 (130 views)
Re: [Franky] RCA F27732SB TV Blows Fuse [In reply to] Can't Post
Thanks
I will test the chopper transistor and HOT to determine how bad is the short.
Also I found another bad diode near the chopper transformer. Hmmmmm
