slinteriors
Feb 6, 2009, 12:19 PM
Post #2 of 4
(6824 views)
Re: [monotech] RCA HD52W59 convergence repair
Thats the convergence board, however the problem is usally re;ated top the smaller baord that is mounted next to that board. The resistors RP610, 611, 612 and 613 sre none to go out. If those resistors check out, then check FL231 on the deflection board. If that fuse is open replace that along with DL231 and CL230 then reflow the solder on the flyback and vertical IC.
