zeekstern
Nov 4, 2010, 1:24 AM
Post #5 of 9
(3762 views)
Re: [darstr] RCA L32HD35D digital channel signal strength is low
 Unless I missed something, why would you need to scan channels if you are using a Sat? Because when I got this TV, part of the setup process that happened when I first turned it on was to scan the channels. It seemed like it would save them, probably in memory(??). Then when you had the option of going thru another step of deleting the channels you did not want to watch. So when I turn the TV on, it would always go to the last channel I watched. Then I could use the remote to go up and down to change the channels. You are also supposed to be able to go into the setup menu and ADD or Delete the channels that you want. When I go to that function now, no channels appear at all. When I turn the TV on, no channels appear. Just that dumb msg in the Subject line:))
