Mar 22, 2010, 11:43 PM
Post #4 of 15
(7386 views)
Re: [dicepackage] RCA LCD Main board compatibility question
"0V" (or low) with set "off" "3.28V" with set "on" (and "stays" all the time the set is on)? If it does, Main board causing is UNLIKELY. I'd start suspecting the inverter board, bad fuse, lytic, open transformer winding, etc. (or bad CCFL bulb(s) is also a possibility). CN2 1-4 VBL: 24.3 5 IL SEL: 0 volts 6-8 GND 9 SEL: 3.28 volts 10 E_PWR: .05 volts 11 I_PWR: .04 volts 12 BLON: 3.28 volts ------------------------- Location: Far, Far Away
