ffejry
Jun 22, 2017, 6:00 PM
(859 views)
RCA LED55G55R120Q - No HDMI signal
Received this 55" TV from my neighbor who said if I can fix it - it's mine. Note: I do not have the remote, unfortunately. So I am unable to use the factory reset mode to see if my problem is fixed - it requires the arrow keys on the remote to confirm. Anyway. Issue: Both HDMI ports - it says "no signal". I have tried all 3 of my Chromecasts and Kindle Fire Sticks. So my initial thought was the board might be an issue. THEN - the HD antenna works just fine. The component cables work just fine as well. It is only the HDMI ports. I have looked into the back panel and everything seems fine. There are a couple plugs that do not have anything plugged into. I do not see a loose wire or anything like that during my brief examination. The picture below shows the board with everything except red circles plugged in. https://ibb.co/mQvO3Q
