Jan 22, 2005, 12:43 AM
Post #3 of 4
(1160 views)
Re: [jjaanice] RCA PS32109 still no sound but I've tried....
I don't have a schematic for that specific model but the last RCA that I worked on with no sound turned out to be a bad audio output IC. If your set has audio in and out jacks, you can narrow it down a little by using them. If you use a VCR audio to the input jacks and it works, you know that the problem is in or before the audio switching circuit. If you have audio on the external speakers, the problem is probably the audio output IC.
