GregSkiAZ
Feb 15, 2005, 12:21 AM
Post #1 of 6
(2832 views)
RCA Projection TV only buzzing
Here is the problem, I have a RCA projection tv in my clubhouse at the apartment complex I work at. Today the Television was on and electric drill was plugged into another outlet in the building and when it was turned on the television made a noise (loud buzzing). The TV was then turned off. Now when the television power button is depressed the screen does not turn on and there is a loud buzzing noise that seems to be coming from the front speaker area. I am not sure what could be causing this noise and not allowing the television to turn on. Any suggestions would be greatly appreciated. RCA Projection Television : February 1993 Service No. P52151WKCG1 Model No. P52151WK Serial No. 307480075 Chassis No. PTK169PTB Volts: 120 - Hz: 60 - Watts (MAX): 240 Please e-mail or Reply to this message @ GregSki+TV@gmail.com Greg @ The Greens Apartments
