kevin
Jan 2, 2007, 1:08 PM
Post #2 of 4
(2369 views)
Re: [1scoot] RCA f27650 picture is too wide
there is no tilt on this model if i remember correctly, the only way to do that would be to rotate the yolk slightly & i think in this chassis the yolk is bonded to the tube. if the picture is streched out the problem is likely in the pincushion circuit. pincushion circuit are typically a small circuit, but usually needs a service manual to trace the voltages & waveforms. look the circuit over you could get lucky & find a visually damaged part in the circuit.
