dfear
Nov 7, 2018, 7:51 PM
(1241 views)
Toshiba 40l1333b (SSL400_05DA) - backlight problem
I have a Toshiba 40l1333b with a backlight problem. Problem: The backlights don't light up. Screen: Lta400hm23 LED Driver board: Ssl400 0d5a- Rev 1.0 Back light LED Strip connector board: SSL400_WP01 REV:0.0 Firstly I replaced the driver board, but that didn't fix the problem. with the replacement driver board connected, I tested the led strips with an LED tester and all the leds light up. I tested the leds using test points VOUT and IS (which are on the led driver board). Also i have checked the continuity from the led driver board to the led strips, and continuity is OK. I think there is a fault with the led driver board. I have attached two photos of the led driver board. The photo with just black test shows what the voltages should be at various points (i found these voltages from a photo I found on a forum). The second photo ( with the green text) show the results of testing the replacement driver board. --------------------------------------------------------------------------------- Any clues which component on the led driver board in faulty? ---------------------------------------------------------------------------------- Update: I replaced the SN358 op-amp with with a LM358, but it made no difference. Here is a number of photos with varying test results ----------------------------------------------------------- correct voltages on SSL400_05DA http://testing.dfear.co.uk/...2-1.black%20text.png results of testing original SSL400_05DA (from the tv) http://testing.dfear.co.uk/...20test%20results.png results of testing replacement SSL400_05DA http://testing.dfear.co.uk/...20test%20results.png results of testing SN358, TR10E and CN001 - original SSL400_05DA http://testing.dfear.co.uk/...-%20ic%20results.png results of testing SN358, TR10E and CN001 - replacement SSL400_05DA http://testing.dfear.co.uk/...-%20ic%20results.png
