Tengugurl
Oct 13, 2019, 5:22 AM
(661 views)
SONY Trintron KV-35S66 not turning on - stuck on standby
Hi! Got this TV a few weeks back to perform an RGB SCART mod in the set and it's been working great over the past week or so. Took the board out today to inspect a wire and it's connection (Green was a little dim so I figured it was a connection issue) Put everything back together per the norm but, I accidentally missed a wire from the neck board. (Woops didn't do a third pass) Tried to power the TV on and it wouldn't turn on, rather, it stayed on an infinite standby. Checked the codes, Infinite blinking (standby) is not a standard error code. I am at a loss. Here is what I did to troubleshoot: connected the missing wire re-tested. Same results inspected the board for caps that looked damaged (none) checked the connections once more (same results) I think it has something to do with the PSU but it looked fine and it's definitely getting power. Any ideas? Thanks!
