imperatormk
Nov 15, 2011, 4:29 PM
Post #15 of 110
(14935 views)
Re: [imperatormk] Samsung CRT no power and ticking noise
So, I took the suggested measurements: The voltage on the center pin ON the board turns out to be ~47VDC... I kinda didn`t understand whether should I measure the resistance between the chassis and center pin ON the board or the disconnected center pin of the transistor BUT, I did the both, so use the one you actually need. Also, I got somewhat different readings when switching the probes:
Black probe to chassis, red probe to center pin on the board: 47.5 KOhm Black probe to chassis, red probe to center pin of the transistor: INFINITY Red probe to chassis, black probe to center pin on the board: 47.5 KOhm Red probe to chassis, black probe to center pin of the transistor: 138KOhm when set on the 200K range, 968KOhm when set on the 2M range. ...and yes; I still can`t find the model number, it just seems not to be written anywhere on the chassis/inside... What now??
(This post was edited by imperatormk on Nov 15, 2011, 6:28 PM)
