eth9966
Nov 23, 2011, 8:28 PM
Post #3 of 7
(15013 views)
Re: [jts1957] Samsung LCD 46 Pop! Then Dead!
Ok, so I tested the fuses and the main fuse, by the power plug, had no continuity so I replaced it. After plugging it in again I heard the same loud pop and then one of the components on the power supply board fried (it smoked / sparked). It is the circled part on the included image. I'm assuming that this is the same exact thing that happened originally (the fuse bursting happened after this). I found the exact replacement board which I can order and easily install. Can any experts here suggest if based on all of this, will the replacement likely fix the tv? Or is it likely that other damage (aside from the power board) has occured. Thanks! http://s12.postimage.org/9c3id9nr1/board.jpg
(This post was edited by eth9966 on Nov 23, 2011, 8:29 PM)
