May 21, 2016, 6:27 PM
Post #5 of 6
(2224 views)
Re: [RichyRich] Samsung UN55ES6550 horizontal lines
TYPICALLY: Main board feeds the Tcon board, it may have a LVDS cable between them, which usually plugs in on both ends. (You may try cleaning/reseating). Tcon board connects to panel, through 1st FFC(s), (one end usually plugs into Tcon, but the other end is 'bonded' to the Source/Driver boards inside the panel). And finally the Source/Driver boards connects to the TFT matrix (Screen), through 2nd FFC(s), both ends being 'bonded.' Choose your poison. The Main & Tcon boards (usually 'USED,' pulled from a 100% working broken screen set) are usually available and usually cost/shipping friendly. LCD panels (if you can locate one) are much less available and more expensive/shipping unfriendly. ------------------------- Location: Far, Far Away
