Jun 24, 2012, 5:00 PM
Post #36 of 49
(3368 views)
Re: [SykoMiko] Samsung crt tv will not turn on.
SykoMiko;.... Knitting has nothing to do with TVs... It's a proverb type saying that applies... The crackling appears to be normal HV coming up when you turn the TV on & going down when you turn the TV off... I wouldn't worry about it unless it gets worse or louder... There are NO adjustments on or for the flyback.... (Only possibly Screen or G2 & Focus) Do NOT adjust them !!!! Yes , pix are going to help.... Around the outside of the CRT is a LARGE coil wrapped on both sides of the CRT... Usually it will be black in color... There will be a wire connected to it that runs down to the chassis... I would appreciate a pix of the area where that wire connects to the chassis... Also will need to see pix of the "blotches" & the "bending or curves" in the corners... PLEASE TRY to take GOOD , CLEAR & IN FOCUS pix.....THANKS....... BEFORE you post the pix , click on "Preview Post" & check the post & pix size... NONE of us here have IMAX monitors , so IF the pix is REAL WIDE , PLEASE delete the pix & post a link to the pix instead....THANKS....... I can not find a manual for this TV so I'm at a bit of a disadvantage with tech info... Electrotanya has a K63A chassis manual that is 25 MBs & will take 2 hours or more for me to download....... I'm thinking about it .... Look around for any loose unconnected wires... Also , run the TV for about 15~20 minutes , unplug it & check to see if the new transistor is getting abnormally hot... Do this by licking a fingertip & then gradually touching the heatsink... Post results....THANKS....... Later...Ron.M........ Veteran & Retired TV technician
(This post was edited by Ron.M on Jun 24, 2012, 5:05 PM)
