yogi40
Apr 19, 2016, 5:00 PM
Post #5 of 5
(1489 views)
Re: [jts1957] Sanyo CE37LD81-B Stuck in standby
Yes the 24v goes to the inverter board, i managed to take some measurements. I dont know how to insert pictures as i have a few that may help. PL803 pin 1. 0v 0.01 then 1back to 0v 2. 0v jumps to 1.3v then back too 0v 3. 0v 0v 4. 0v 0v. this is a yellow wire and shorted to ground 5. 0.5v jumps to 2.5v then back to 0.06v 6. 0.4v 1.75v 7. 0v 0v 8. 0v jumps to 11v then down to 0v 9. ground 10. ground PL602 measure all good PL403 buttons measure all good this is the mainboard PL002 1. 0.65v - 5v 2. 0.51v - 3.36v 3. 0.51v - 3.36v 4. G 5. G 6. G 7. G 8. 0.51v - 3.35 drops to 0.2v 9. 0.52v - 3.35 drops to 0.18v 10. 0.52 - 3.35 drops to 0.17 11. 0v - jumps to 4v then drops to 0v 12. 0v - jumps to 4v then drops to 0v When i disconnect PL003 from the mainboard the 3.3v pins on PL002 dont drop. I took some resistance measurements with power disconnected PL802 this is the 24v rail that goes to the inverter board 1. 1.04k 2. 1.04k 3. 1.04k 4. 1.04k 5. 1.04k PL813 1.G 2 G 3. 7.1k 4. 7.1k
(This post was edited by yogi40 on Apr 19, 2016, 5:02 PM)
