ozman911
Apr 21, 2012, 6:35 AM
Post #32 of 35
(4510 views)
Re: [jts1957] Sanyo DP32648 Lightning Hit
All, I presume, are associated with the power supply unit (?1AV4U20C17201?) which I don't believe has any schematic coverage in any SM mentioned. SM does show Ins/Outs only on a block diagram. Resistances seem O.K. Yes,, Sorry I forgot to mention that they were all located on the the power supply unit. I have been trying to locate a schema for the power board but to no avail. Heres what I know so far just to recap the situation. 12v and 24v output from the power board are both dead. 5v standby from the power board is good. PSON is receiving a 5v signal when the set is turned on, but is shut down 10 seconds after being turned on (presumably by IC800 not sensing a 12v or 24v presence). All Rectifiers, mosfets, MOV's, resistors, and diodes that are not smd have tested good. All capacitors have been replaced with new ones of equal value. The small transformer is working correctly and providing the 5v line. The larger transformer is recieving 120v when the set is powered on. This voltage slowy dissipates after the sets turns of on its own. On the secondary side of the large transformer I am only getting a 7v+- from one of the legs (could be two I will double check this tomorrow). So from what I can tell, the 5v standy is operating correctly. The main board is operating the start-up circuit correctly. The power supply start-up circuit is being triggered correctly and supplying AC to the primary side of the 12v / 24v transfomer, I have pulled the transformer from the board and checked it for shorts / opens. All seems to be ok here unless I missed something. Well its time for me to pack it in for the night. I will try to get some good pics of this board in the morning. Thanks a million for all the help so far! This is quickly becoming personal between me and this tv set. :)
