Feb 4, 2018, 12:12 AM
Post #4 of 4
(715 views)
Re: [Codar] Sanyo LE26LD47 blown psu
Have 17PW26-3 mains fuse gone, chopper damage and D893 and C931 on the 30V supply blown.... all resistors check OK around the chopper. I have a 17PW26-4, so in it went and the set worked merrily away. Can anyone shred light on the difference between a 17PW26-3 and a 17PW26-4 power board? Thanks, Dave. Thanks for links. It's worked fine, the -4 board will work in place of the -2 board, I can't say if it'll work the other way round, that is a -4 board being swapped for a -2 board. Dave And ah 1 and ah 2: https://elektrotanya.com/...-1.pdf/download.html https://elektrotanya.com/...ch.pdf/download.html ------------------------- Location: Far, Far Away
