Electro
May 30, 2005, 7:14 PM
Post #5 of 5
(1052 views)
Re: [mel] Screen turns Red, hor. lines can be seen
Most probably, the board behind your picture tube has a loose socket. Turn off the power. Try pulling it off (carefully) and plugging the board back in, several times. This usually solves the problem. If excessive arching occurred, you may have to scrape the leads on your picture tube clean (use a fine grain sandpaper) before plugging the board back in. If this doesn't work, then it could be a loose solder joint. reheat the electrical joints of the socket with a soldering iron. If you have to add solder, clean off the excess rosin with a quick brush of thinner. Let dry, and test again. Logic is, since it's temporarily solved by pressure applied on the board, it's a loose connection problem on that part. Don't tweak on the variable resistors. You may not be able to return it to it's peak color mix. Gud luck
