Sharp Aquos black screen, but screen comes up for a moment when turning on (kinda fixed)
pzoom
Oct 22, 2016, 9:20 PM
Post #1 of 4 (7411 views)
Sharp Aquos black screen, but screen comes up for a moment when turning on (kinda fixed) Can't Post
I edited this post with some new info. I have heard the 70LE660u has same issue.
Sharp Aquos 60" 60LE660u, black screen, no sound. LEDs come on, seems to have power. When I push the power button to turn ON, I can see the screen come up including backlight for a moment.
I have replaced the T-con and Main controller board but it acts the same.
TV is a little over a year old, just went off one day.
When I pull one of the TCON ribbon cables, the screen comes on. I can then re-insert the ribbon cable and the TV works. However if the TV stays off for more than a few hours, I am back to the original problem.
If I put the TV in "wallpaper mode" where the screen stays on (but low power), it will come back on. Any ideas?
Also, I put a wattmeter on the TV and it draws 30W in wall paper mode if anyone is interested.
(This post was edited by pzoom on Nov 1, 2016, 12:48 AM)
Oct 23, 2016, 1:08 AM
Post #2 of 4 (7404 views)
Re: [pzoom] Sharp Aquos black screen, but screen comes up for a moment when turning off [In reply to] Can't Post
May want to follow troubleshooting in Service Manual: http://badcaps.net/...ighlight=lc-60LE660u
or http://elektrotanya.com/...0u.rar/download.html
pzoom
Oct 23, 2016, 9:13 PM
Post #3 of 4 (7397 views)
Re: [jts1957] Sharp Aquos black screen, but screen comes up for a moment when turning off [In reply to] Can't Post
I downloaded the service manual and tried the things they suggest.
The LCD lights up for a moment when I plug it in and then again when I turn it off (and I can see info on the screen for that brief moment). I am going to order a power supply board next and see what happens. That is the only board I haven't tried to replace lol
The manual says the power LED should flash a sequence when the unit is plugged in if there is a supply issues. However the LED comes on and stay solid when I plug it in and it goes off when I push the power button.
pzoom
Oct 23, 2016, 10:51 PM
Post #4 of 4 (7391 views)
I pulled one of the flat cables going to the LCD (there are 2 cable on the t-con board). I powered back up and half the screen came up!
I then inserted a USB stick with the latest firmware and installed.
I then powered off and re-connected the cable. The TV works now - however there are 2 small horizontal lines towards the bottom of the screen.
I tried swapping the new T-con board and I have the same issue.
Not sure where to go from here, but at least the TV is usable.
Hopefully this post helps someone....
