Apr 18, 2008, 4:28 AM
Post #3 of 5
(92 views)
Re: [ned310] Single Horizontal Line on Panasonic CT-32G5B
Until the other guy said it could be the supply I agreed with his rant but no, he is trying to build up issues. Doing so he must be correct, he just erred. Its the vertical chip, and yes its IC 4xx now you also need to check the feed resistor because that got a serious zap as did the feed diode, and the doubler capacitor may be an issue, other than that its 99% certain the set is OK.
