Jan 20, 2016, 12:01 PM
Post #10 of 10
(2382 views)
Re: [HelpMeThanks] Sony Bravia kdl-32R330B More info post
http://www.tvparcasi.com/...philips-32pfk430912# the center and right-hand smaller pictures under main. LEDs surface mount to the front of the board by solder. Lens then is installed over LED with three pegs/mounts at 3pm, 7pm & 11pm that are softened (melted) and pressed from BACK of board. The strips come off panel, so metal is of little concern. You either want ALL old or ALL new LEDs. Not mix & match. As long as 21 NEW LEDs meet your budget. 3.6V high current/high brightness, not sure what 'light temperature.' I doubt that you will find any 'NEW.' Sony (or any manufacturer, for that matter) cares about the funds they make on the initial purchase and if any consideration for replacement is/was considered, it is panel replacement. The set looks so good with back light controls at maximum. Even at that setting, the TV should make it through base warranty. So what if at those settings the life of many parts (including back light LEDs are shortened. SAME thing WILL occur AGAIN if controls are NOT reduced. ------------------------- Location: Far, Far Away
(This post was edited by jts1957 on Jan 20, 2016, 12:03 PM)
