Sony KDL-46Z4500 Completly Dead
max1636
Dec 22, 2013, 11:51 AM
Post #1 of 10 (3295 views)
Sony KDL-46Z4500 Completly Dead Can't Post
I've got a KDL-46Z4500 with what I believe to be a faulty power supply board. Part No. 1-877-271-12 I am getting no standby codes and no standby voltage and the pin on the main output connector. However when I unplug the T-Con board connector I get a very small reading less than a volt but I don't believe the T-con is faulty I just think it's trying to draw current but It can't.
I have some experience repairing TV's and really want to repair this board instead of just buying a new one. There are a few components I have tested or replaced from another working Sony board, which include:
- Main 150uf 450 Caps
- Bridge Rectifier
- Main Relay
- Standby Transformer
- 0.22uf and 10K Cap right beside the mains input
plus the other 0.22uf and 10K cap after the coil/choke things
I have also tested with my ESR meter all the caps beside the main output connector all measuring fine. The fuse is also fine.
I did find something unusual with the main 450v Caps, with only the mains power connected they only very very slowly charge, after a few minutes I was only reading half a volt, and after a few more I wasn't even up to a volt.
Dec 22, 2013, 5:30 PM
Post #2 of 10 (3277 views)
Re: [max1636] Sony KDL-46Z4500 Completly Dead [In reply to] Can't Post
Are they before or after the relay?
http://elektrotanya.com/...fo.pdf/download.html
Above has a very small service manual for your model - What is the full EG1L-? chassis number?
max1636
Dec 23, 2013, 1:32 AM
Post #3 of 10 (3264 views)
Re: [jts1957] Sony KDL-46Z4500 Completly Dead [In reply to] Can't Post
I presume you mean the 450v Caps? I'm afraid I couldn't tell you. As mentioned they very slowly charge just with the board connected to mains and at no point does the relay click. Where can I find that chassis number?
Dec 23, 2013, 4:10 AM
Post #4 of 10 (3261 views)
How about 'Location' numbers (C6529, RY6000, etc.) for parts already mentioned?
max1636
Dec 23, 2013, 4:17 AM
Post #5 of 10 (3259 views)
Here is the best shot I can get of the bottom of the board, does this help:
http://i1208.photobucket.com/albums/cc364/max1636/20131223_141314_zps56376839.jpg
Dec 23, 2013, 4:46 AM
Post #6 of 10 (3258 views)
I can't make out the location numbers - anything smaller than the board number.
max1636
Dec 23, 2013, 5:00 AM
Post #7 of 10 (3255 views)
This should be much better, same image but high resolution:
http://extrazoom.com/image-8187.html
Dec 23, 2013, 12:09 PM
Post #8 of 10 (3248 views)
Hook everything back together. (Preferably 'correctly.')
NOTE: EACH board has 'Sony plus letter(s) &/or number(s)' on them.
I'm asking for voltages on two different connectors, one each on two different boards.
110-240VAC CN6000 on G6?
5VDC CN2800 #7 on FBA?
(This post was edited by jts1957 on Dec 23, 2013, 12:11 PM)
max1636
Dec 23, 2013, 12:49 PM
Post #9 of 10 (3242 views)
Thankyou very much for your help but I've decided I'm going to completely replace the power board.
Dec 23, 2013, 1:29 PM
Post #10 of 10 (3240 views)
Just hope set has a good AC cord.Wink
