Dec 23, 2010, 3:48 AM
Post #50 of 57
(3073 views)
Re: [brownboi] Sony KDP-57WS550 led blinks 4 times
brownboi;.... Try this;.... Granted that this set has been working for awhile without any repairs from me or you.... It's possible that since the set comes on OK & works OK that it may be a mistake in the code... So reset it as explained below... Do NOT DO ANYTHING else when in the service mode or you can screw up the TV PERMANENTLY... IMPORTANT: After you repair the unit, you MUST clear the values on this diagnostic screen. These codes do not reset themselves after the fault is corrected, so if you don't clear them, you'll be seeing "old" fault codes the next time you enter this screen. Clearing is done by going into the service mode (display, channel, 5, volume plus, then power ). (EDIT Ron.M >> ...Pause for a couple of secs here , then proceed) Press 8 and Enter, which returns everything to the factory preset condition. The turn the TV of with the power button ON the set , NOT the remote.... Let me know if this worked ..... Later...Ron.M....... Veteran & Retired TV technician
